Megasquirt expected "MSII Rev2.88600" recieved "MSII Rev2.8880"
Old Nov 22, 2008 | 01:02 PM
ITSWILL's Avatar
Wiring Nightmare
how do I fix this?
Im building the MS and I have setup the serial communication and am trying to run megatune properly but I think it is messing up due to that error.
Nevermind I think I fixed I forgot to download "megasquirt-II.ini.2.8"
Old Apr 17, 2009 | 07:56 PM
Whizbang's Avatar
Respecognize!
i have having this same issue. I downloaded the Megasquirt-II.ini.2.8 file and put it with the other files (so i think) but it doesn't recognize that i did so and the error still comes through. There is no option for that version in the list that megatune brings up.
Old Apr 18, 2009 | 08:41 AM
nu-rx7junkie's Avatar
You will have to save the ini or s19 file in megatune so you can activate it.
Old Apr 20, 2009 | 02:15 PM
muythaibxr's Avatar
MegaSquirt Mod
Keep in mind that the standard ms2 firmware will not run the rx7 ignition system.
You need to get ms2/extra to do that. Check the firmware sticky at the top of this section of the forum.
The problem you guys are having is that you've got an ini version that does not match the firmware on the ms2.
Ken
djSL
The Bad & Fugly Businesses
24
Sep 21, 2017 03:09 AM
LongDuck
Oct 7, 2015 08:12 PM
Jmolina0163
19
Sep 25, 2015 06:06 PM
apooch
Sep 4, 2015 10:27 AM
