Finally FIxed my boost issue, 10-8-10
Old May 16, 2002 | 08:43 AM
NeedTwins's Avatar
I have been plagued by a gremlin. I thought that it was vacuum related but that was not the case. Apparently the guy who sold the car didnt want to get down and dirty. I peeled back some heat sheilding near the pre-cat and found that the turbo control actuator, I believe, the farthest one back, was disconnected. THe rod had come off the arm due to a missing c-clip. I am still leaking a bit of oil but now I can do it under boost.
Old May 16, 2002 | 09:50 AM
warsaw's Avatar
I'd kill for a 10-8-10 pattern. Unfortunately, mine is like 6-4-6 or 8-6-8 -- and it SUCKS.
I ran a 14.2 @ 98 at the track, but I had to shift really slowly b/c of my hot clutch. Does this number look right to you if I was boosting on those lower patterns?
Old May 16, 2002 | 10:07 AM
NeedTwins's Avatar
I am by far not the expert, but from what I understand that is a bit slower than stock. You have a consistent pattern just low. Hae you swapped out your pre-cat. how many miles.
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
Microtech
30
Apr 23, 2016 06:37 PM
tsmith94FD
Aug 16, 2015 05:41 PM
