how long before it affects temp?
Old Nov 17, 2008 | 05:54 PM
AlexG13B's Avatar
brap brap brap
this is for the guys who put thier nozzles before the IAT. how long does it take before the sensor will show the colder temps? is it instant?
Old Nov 18, 2008 | 12:31 PM
stylEmon's Avatar
FC since 99
Mine is near instant and no where near my AIT sensor. tho you should not spray right at your AIT sensor. It will yield an incorrect reading from being saturated.
Old Nov 18, 2008 | 06:21 PM
AlexG13B's Avatar
brap brap brap
my nozzles are placed afew inches before the ait, and doesnt show the temp decrease.
Old Nov 23, 2008 | 03:59 PM
IAN's Avatar
IAN
Rotary Reborn!
15" before the ait and no temperature difference seen on the haltech sensor,
Running -40 windshield fluid as injection.
Old Nov 26, 2008 | 05:08 PM
AlexG13B's Avatar
brap brap brap
wow thats interesting i wonder why.
Old Nov 28, 2008 | 08:10 PM
stylEmon's Avatar
FC since 99
Here is the 2nd nozzle. More than a foot away from the AIT sensor.
I've heard that there is methanol in washer fluid, but there is other 'crap' in some that i may not want in my motor.
Old Nov 29, 2008 | 03:25 PM
AlexG13B's Avatar
brap brap brap
ya stay away from the colored ones that contain anti freeze like the yellow or orange ones
the temp sensor should show a temp difference, plenty og other guys do it i think
Old Nov 30, 2008 | 12:56 PM
ktm240z's Avatar
I see a huge temperature drop nearly instantaneously. I logged the IAT with my Innovate LMA3 and you can see the temperature drop. I am running 100% methanol though.
Old Dec 4, 2008 | 05:07 AM
Azcamel's Avatar
Put it in her butt
i see no temp drops either, mine is about 6inches from my AIT, run only water..
anyone know how to add a status light to varify its working?
Old Dec 4, 2008 | 09:07 AM
stylEmon's Avatar
FC since 99
you need a pressure sensor. Wire it into the pump and wire an LED to the sensor. The one i got is adjustable.
Old Dec 4, 2008 | 03:36 PM
Azcamel's Avatar
Put it in her butt
do you have a diagram, place to buy this? i have a coolingmist one and dont understand their sensor instruction, i have a hobb switch also.
Old Dec 4, 2008 | 06:53 PM
AlexG13B's Avatar
brap brap brap
apparntly mine isnt working. i checked it for giggles, turned on pump and do really see anything coming out of nozzles. i check after the check valve and nothing, apparently its not opening the check valve.
Old Dec 8, 2008 | 12:17 PM
stylEmon's Avatar
FC since 99
I am doing mine now. I am using a pressure sensor from Aquamist (I think), and wiring it to a switch. There will also be an LED wired in to tell me if the pressure drops below 120 psi.
I'll take pics and document for ya.
Old Dec 9, 2008 | 01:59 AM
Azcamel's Avatar
Put it in her butt
sweet, thanks!!!
Old Dec 17, 2008 | 07:55 AM
AlexG13B's Avatar
brap brap brap
anyone got datalogs?
Old Dec 19, 2008 | 07:08 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
i don't think that intake temperature readings are going to be the key if you are running water. water gives up it's latent heat in the combustion chamber, not in your runners. (not saying there isn't a little cooling, but not much).
further, i recommend that the AIT sensor be moved to the tube between your IC and engine for heat soak reasons.
hc
rx7jocke
72
Jun 17, 2016 03:48 AM
ZacMan
Sep 19, 2015 09:20 PM
vmerino
Sep 5, 2015 11:26 AM
