is stock fuel pump good for these mods
Old May 15, 2002 | 09:04 PM
T88Rx7's Avatar
3inch from turbos back, pully, pettit unlimited, intake, intercooler
Old May 15, 2002 | 09:08 PM
Mahjik's Avatar
Mr. Links
You really don't need to upgrade the fuel pump until you start looking into larger injectors. Even then some people still run the stock pump depending on their needs.
Old May 15, 2002 | 09:39 PM
Johnny's Avatar
OG
at stock boost maybe...push 12psi or higher and I agree with Mahjik
Old May 15, 2002 | 10:26 PM
Cetchup's Avatar
The Cursed FD
also, if you are on the bottle (Nitrous Oxide system) u will probably want an upgraded fuel pump because people usually dont know how big of a N20 shot to use and they wont have enough fuel to compensate for their foolishnes. However i see that you are not, so disregard that statement =)
Old May 15, 2002 | 11:23 PM
user 84205's Avatar
ya without a bigger turbo, or upgrade... You really dont need it unless also you have a sideport engine..
Old May 17, 2002 | 01:39 AM
gzon's Avatar
I have seen a guy pulled out 450Hp out of a mazda 323 GTR engine (1.8 DOHC with huge BB turbo standard) and he was using the FD fuel pump, how can that be possible if the FD runs out of fuel at less than 400Hp?
Old May 17, 2002 | 01:54 AM
user 84205's Avatar
maybe because the injectors are smaller.
Old May 17, 2002 | 02:17 AM
jspecracer7's Avatar
1JZ powered
Piston engine's use less fuel to make the same HP. Fuel pressure is higher in FD's...
Old May 17, 2002 | 12:06 PM
Wade's Avatar
No, you don't need to upgrade the fuel pump until you want to upgrade some other part of the fuel system (injectors, higher fuel pressure, etc.) I have tested this and the stock pump maintained fuel pressure on my car at 15psi of boost (hitting 100% injector duty) and stock pressures. When I tried to raise the fuel pressure by 5-10psi the pump would have problems.
Wade
immanuel__7
89
Sep 5, 2015 10:23 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
