Bridgeport question
Old Nov 15, 2008 | 12:11 PM
Aeka GSR's Avatar
Bridgeport question
I am under the impression that I am not supposed to use the rubber plugs in the corner seals on the bridge side, correct?
Am I also correct that the apex seals must be flipped so the triangles do not ride on the bridge side?
Old Nov 15, 2008 | 01:20 PM
2Lucky2tha7's Avatar
Back at it again!!
No.
Unless you are referring to partial bridge engines (where only the secondary ports are bridged), then I can see why you would ask that due to the 2nd rotor having the triangle piece facing the bridged side
Off the top of my head, I can't remember about the rubber inserts on the corner seals, but I am under the impression that they will fall in in short time. However, take take my word for that, as I've only street-ported all the engines I build. You can opt for solid corner seals from Atkins though...
Old Nov 15, 2008 | 03:19 PM
Aeka GSR's Avatar
whoops, yeah i should have been clear on what engine i am doing. 13brew with the Bridgeport on the secondary side.
Just so im not misunderstanding you, I would need to flip the seal on the one rotor? I'll check out the solid corners seals, any drawback to using them?
Old Nov 16, 2008 | 12:33 AM
ultimatejay's Avatar
Use the solid corner seals, they are better and yes the rubber plugs will eventually fall into the engine and may cause damage if used in a bridgeport motor. Plus all they do is aid on start ups.
If running a half bridge then yes you would have to flip the seals so the corner piece is facing the primary ports and not the bridge ports.
Old Nov 18, 2008 | 11:52 AM
BNA_ELLIS's Avatar
Does it matter that much ? I seen few full bridge running 2 piece seals.
What advantage does 1 piece seals hasve on a full bridge?
rgds
Brian
Old Nov 18, 2008 | 11:08 PM
rgds
Brian
Depends on how big the bridge is. I heard of the small triangel piece of the seal falling into the port.
Old Nov 30, 2008 | 04:20 PM
mono4lamar's Avatar
In the burnout box...
You always face the smaller piece away from the secondary ports on a half bridge. If you understand the reasoning to this then you can understand the benefits of a one piece apex seal on a full bridge setup.
Old Nov 30, 2008 | 05:21 PM
joeylyrech's Avatar
87 SE WITH S5 T2 SWAP
Flip the seals around so the small piece faces the intermedia plate,im running a HBP with the rubber plugs only removed on the bridgeported plates(i keep the ones facing the center plate)and is start right up and i dont have comp. issues.120PSI
_Tones_
May 25, 2021 05:37 AM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
risingsunroof82
Sep 9, 2015 08:06 PM
Nosferatu
Sep 5, 2015 02:13 PM
