Hi, Trying for a S5 13b turbo swap
Old Nov 13, 2008 | 07:31 PM
Nikamas's Avatar
Born To Drive
Hey, I have had my '88 RX-7 for around a year now and i think i am ready to start upgrading. Its a N/A GTU and i am thinking about swapping for a S5 turbo engine. Just wondering what it all entails and needs to be done. Can i just drop it straight in? Or do i need to do some other things?
Old Nov 14, 2008 | 10:17 AM
Icemark's Avatar
It is much easier to swap the same series, such as since you have a S4 (1986-1988) it is easier to use a S4 Turbo motor if you want or need to do a swap.
Also the S4 rotors are stronger and last longer than the S5 and later versions, as well as you won't have to worry about the MOP (Metering Oil Pump) issues with the electrical MOPs that the S5 and later models have.
There are a lot of swaps covered in the technical section and FAQ's as well as all over the internet, but the amount you are willing to spend will determine what parts you need.
At the very least to do the swap you will need a S4 or S5 Turbo long block and engine wiring harness (or modify your existing engine harness) and some sort of either factory or aftermarket ECU (engine computer) and a Turbo hood (or a front mount intercooler if you retain your stock hood).
Then it is recommended that you also replace the transmission, drive shaft, differential/rear end assembly and the half shafts with their Turbo versions.
Of course if you replace the transmission you will also need to replace the starter, flywheel, clutch slave cylinder, and mounts.
Generally I also recommend replacing the front springs as well since the Turbo engine and transmission combo adds about 100 lbs to the front end of the car.
As far as the swap goes, a good mechanic can do a full (all the above mentioned items) swap, easy in a weekend, but your average shade tree mechanic may take longer.
Old Nov 14, 2008 | 08:15 PM
Nikamas's Avatar
Born To Drive
Your post has answered alot of my questions. thank you! I already had it in mind to get a new tranny so thats not too bad. Doesnt seem to be anything too dificult. Ill check around to see what options i have and read up on swaps others have done to be prepaired.
again thank you for you info!
Old Nov 14, 2008 | 10:02 PM
Tom Bush's Avatar
you need engine,trans.,ecu,wie harness,downpipe,exhaust,& a fiew odds & ends.I would sugjest a aftermarket systom approx.$1k to buy -end result 100 more horses than mazda speed turbo swap
Old Nov 15, 2008 | 01:01 PM
Nikamas's Avatar
Born To Drive
I took a look at some of the ECUs in the forums. What would be a good one?
Machupicchu
Aug 17, 2015 08:27 PM
Machupicchu
Aug 15, 2015 05:57 PM
Engine stand ready
Aug 14, 2015 10:26 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
