Sponsored by: CARiD
How many oil lines/injectors from OMP on an FD?
Old Nov 13, 2008 | 06:37 PM
jetlude's Avatar
BadAss DoItYourselfer
Just installed new engine management system which will not run the OMP. I want to block the injector port and lines but leave the OMP in place (disconected) is this possible?
Old Nov 13, 2008 | 06:49 PM
bumpstart's Avatar
talking head
s6 EOMP has two lines, two oil injectors
- to stop its operation yet leave the EOMP fitted
its best to block the suction to the EOMP pump, via the passage in the timing cover gasket
( blocking in the discharge outlets is not the best option as it will force a leak )
also disconecting the EOMP and leaving it in the oil system
will amount to fixed rate injection from its last known setting
BTW
here is the other option -
http://www.eomp.info/
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
