FC alt to FD alt
Old Nov 10, 2008 | 11:20 PM
galaxy convoy's Avatar
Undercover
FC alt to FD alt
Anybody here knows a good place that can change an FC alternator into an FD alternator? Im already tired of having very low voltage on my S4 with my lights and rear defroster on. Ican only get 13.9-14 volts w/ lights off and 13.5 w/ lights on or 13.2 when i applied my brakes
thanks for the help!
Old Nov 11, 2008 | 09:16 PM
jkstill's Avatar
Searching for 10th's
Cleaned your battery connections lately?
Checked the tension on the alternator belt?
If that's all good, why not just take it to an alternator rebuild shop and tell them what you want?
Old Nov 11, 2008 | 09:53 PM
Otay's Avatar
Blah, Blah, blah
https://www.rx7club.com/showthread.php?p=8630624
That thread should help you out.
Also I happen to have an FD alt I've been holding onto for a while. I'll let it go for $50 if you want it.
Old Nov 12, 2008 | 08:22 PM
MWMburton's Avatar
jkstill is right. a dude walked into my work n told us the place next door (auto electric and battery) converted his alternator to a generator (ac to dc) pretty b a
Old Nov 13, 2008 | 12:29 AM
Rx7TyreBurna's Avatar
Becoming pure track...
Alternators are generators..... and the generate DC voltage...... I think your friend maybe got ripped off? Or, it doesn't sound like you are saying the right stuff.
An alternator spins a coil of wire, inside a coil of wire and induces a voltage, which is then rectified into a dc voltage....
Old Nov 16, 2008 | 11:48 AM
endneu913's Avatar
Turbo Waggin
FC To an FD is easy, change the wiring around around, get a new double pulley to be BA. and your set. That link above is prolly the same wiring diagram thats been floating around forever. And $50 for that alt is a steal, buy it!
Old Nov 16, 2008 | 07:44 PM
Undercover
But yeah im not good at electronics and i dont want to mess up my wiring harness
Old Nov 19, 2008 | 10:09 PM
endneu913's Avatar
Turbo Waggin
Dont let the word "diagram" scare you... its like 2 wires.
Old Nov 22, 2008 | 04:12 PM
cosmo105's Avatar
Your voltage isn't bad. The only reason to change to an FD alternator is for the amps. FC has 80 amps, FD has 100 amps.
Captain Hook
13
Oct 4, 2015 06:35 PM
airjordan223
24
Oct 4, 2015 04:42 PM
FC3S Timmy
Oct 2, 2015 08:08 AM
FC3S_nataku
Sep 15, 2015 12:36 PM
