RE Amemiya Redom Type B ECU good?
Old Nov 7, 2008 | 01:53 AM
Fine2NR's Avatar
I have been working on the exterior of my car for some time now. I have been gathering parts for the motor and am soon ready to start installing them. I have a ARC intercooler and Radiator, RE dolphin tail exhaust, hi flo cat, hks intakes. I bought a RE Amemiya Redom Rom type B with Boost switch. I was wondering since it is for JDM will it work on USDM cars? Would I have to use higher octane gas? Or am I better off with a Power FC? Any help would be great. Thanks!
Old Nov 8, 2008 | 06:52 PM
redlinedrift's Avatar
I've got a friend with one, power gains are pretty decent, he runs 100 cotane+.
Old Nov 9, 2008 | 11:21 PM
Fine2NR's Avatar
Wow... 100 octane? Is that necessary to run with that setup? So 91 pump gas can't be used?
Old Jun 1, 2012 | 11:23 AM
boostaddictB89's Avatar
IL
i was looking at one on ebay too, the fc3s amemita redom boost up ecu.
i have a 89 swapped with a 91 T2 motor and was wondering if you can use this ecu with a stock fuel delivery system and injectors and not run lean under boost .
as it is now, i have a FMIC 3 inch down pipe, full exaust, intake , bov, HKS fuel cut defencer, and a HKS non programable piggy back for the fuel system, i think its called the FMSC???
can anyone give me some pointers on this ?
or has anyone ever used one of these before?
is it re-tuneable?
Old Jun 1, 2012 | 11:26 AM
the piggy back im using is called the PFC F-CON
Old Jun 1, 2012 | 11:42 AM
dwb87's Avatar
This is my social media.
I've not found much information in regards to the RE-Amemiya tuned ECU's. Obviously they're tuned to specific set-ups. (e.g. Bigger secondary injectors, open exhaust, different turbo, etc...) - There's really no telling what you have unless you're able to source the information. There has to be a diagram or brochure somewhere. It is most likely in Japanese, but that would at least be a big first step.
Old Jun 1, 2012 | 12:16 PM
scribo's Avatar
Fuel between the two countries are rated differently.
100 RON Octane (JP) x 0.95 = 95 AKI Octane (US)
93 or 94 octane should be fine.
Old Jun 1, 2012 | 01:17 PM
well i found another ecu thats "chipped" called the Rtek7 .
the link is listed below:
http://www.pocketlogger.com/index.ph...age=2&ecu=S4T2
im not sure if it is fully programmable or not tho . picture from seller shows the computer cords (wich would only make sense if its tuneable)
idk , to be honest im no expert in engine management systems .....
Old Jun 1, 2012 | 01:53 PM
all rotor's Avatar
Made 325 rwhp on RE Amemiya type B ecu , with dp and full 3 inch exhaust . Medium smic , intake . Used 95 octane (ron) . @ 1bar of boost
Old Jun 1, 2012 | 02:03 PM
ALL ROTOR,
u made that on what size injectors?
and a 255lph im guessing?
Old Jun 1, 2012 | 02:20 PM
all rotor's Avatar
The injectors were stock and the pump was a 255 walbro . Used a greddy profec b spec 2 , to control boost . Boost was rock solid till 7400 rpm
Old Jun 1, 2012 | 02:22 PM
damn thats impressive, im guessing you had a FPR?
Old Jun 1, 2012 | 02:38 PM
all rotor's Avatar
Thanks man... The FPR was stock as well
Old Jun 1, 2012 | 02:45 PM
wow , and you wernt running lean under full boost? that sounds like a cheap way to get hp lol
Old Jun 1, 2012 | 02:59 PM
and what about wastegate? stock,after market, ported, external? gimme the good stuff here lol
Old Jun 1, 2012 | 04:18 PM
all rotor's Avatar
Had a ton of other mods , but power wise , it was stock engine and stock turbos . Just those bolt on stuff .
95 JDM fd3s
Old Nov 27, 2012 | 11:37 AM
I have the same ecu only for a S5 FC for my car and I've been trying to get some info on them too with little luck
One person had said they made about 319 on that ecu on an S5 motor with stock turbo , ported wastegate flange and other bolt ons on stock injectors ...
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Jester's Toybox
Aug 18, 2015 06:03 PM
