fuel boiling after shutoff.
Old May 14, 2002 | 08:33 PM
Siraniko's Avatar
RX for fun
my rx-3 has a stock 12-a with a dellorto + heatshield + one piece rotary reliability intake manifold. . i cant figure it why the fuel inside the fuel bowl is boiling after shutoff . can some1 explain this to me?
Old May 15, 2002 | 12:35 PM
jbontke's Avatar
Damn security clearances
Well it looks like your are still getting heat from somewhere. Try header wrap for the exhaust and look where your fuel line runs. It can pick up heat. Maybe the heat shield between the carb and intake isn't good enough....try space shuttle tile
Old May 15, 2002 | 03:43 PM
Siraniko's Avatar
RX for fun
actually, i noticed similar problem using the stock rx-7 carb prior to the upgrade. I even put it back last night and i got same result.
Old May 21, 2002 | 12:41 PM
Darth Linux's Avatar
i had this type of problem on my rx-2 when one of my floats was set wrong. it only spit gas out of one side of the carb so I took the top off, checked the settings of the floats and the one that was boiling out was letting the fuel level get too high. I made it go lower and the boil over after shut down stopped. . .
ymmv
Old May 21, 2002 | 09:05 PM
Siraniko's Avatar
RX for fun
thanks. i will ck that.
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
