Canadian Forum Canadian users, post event and club info here.
Thanks to Dragonwerks Dyno
Old Oct 30, 2008 | 07:16 PM
IAN's Avatar
IAN
Rotary Reborn!
Thanks for Jo for yet again for having the patient to sit there and see the blank look on my face as I try and manipulate myself around the new version 1.89 Haltech E8 throttle pump setups for a quite a few hours.
Anyhow more progress has been made and the new version of Haltech E8 software had a few bugs worked out of it. The more I use the hlatech software the more easier it gets.
Thanks jo.
http://www.dragonwerks.ca/index.html
Ian,
Old Oct 30, 2008 | 07:38 PM
eViLRotor's Avatar
Brother of the Rotary
...and the more fuel fumes and radiation you are exposed to, the more difficult it becomes to spell Haltech, apparently.
Old Oct 31, 2008 | 04:53 AM
IAN's Avatar
IAN
Rotary Reborn!
And aluminum dust!
Old Oct 31, 2008 | 10:48 AM
eViLRotor's Avatar
Old Oct 31, 2008 | 04:39 PM
IAN's Avatar
IAN
Rotary Reborn!
Dam you. At least show a picture without the double chin.
And quite being a post *****!
Old Oct 31, 2008 | 06:23 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
aluminum dust is actually pretty bad for you.
Old Nov 1, 2008 | 01:39 AM
eViLRotor's Avatar
I know, look what it's done to Yeti!
Old Nov 1, 2008 | 06:24 PM
Leigh Adams's Avatar
Struggles with Idling
well what are the numbers you put down???
Old Nov 2, 2008 | 03:45 PM
IAN's Avatar
IAN
Rotary Reborn!
Same old numbers. 407rwhp at 15psi Dyno Jet. 400rwhp at 18psi Mustang Dyno. I was just trying to improve driveability/staging and throttle pumps.
The only pull we did to see dyno numbers was 360 or something at 15psi.
I will be back to play with high boost once I get an ignition map but really higher hp #'s will not appear. Turbo is getting out of steam. I'm just turning up the boost to get more bottom end. (5000rpm etc)
Old Nov 18, 2008 | 12:34 PM
Cheers!'s Avatar
Former Rx7 *****
WTF are you running 15 psi for you pansy! I thought Nik and I tuned your stupid car for 21 psi. You should be aiming for 25 psi.
Old Nov 18, 2008 | 04:41 PM
IAN's Avatar
IAN
Rotary Reborn!
That day wasn't about high dyno numbers. It was for more fuel triming. And higher boost I will wait for a igntion amp.
Drive you car pansy!
Old Nov 19, 2008 | 12:16 AM
Terrh's Avatar
you've probably got the best rotary ever built anyway... how many KM's are on it now??
Rotate86
May 18, 2018 02:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
