Megasquirt MS map For DIYautotune
Old Oct 28, 2008 | 10:33 PM
Smokems's Avatar
I love my 13bT
umm i was just wondering...if anybody had a map for the Megasquirt from DIY that is set for a halfbridge setup...i just need to get the car to start....tomorrow and I was just wondering if anybody had it. Let me know asap. thanks again...
PS im new to tuning and such....would any map work from any standalone as a guide...or does it have to be MS specific?
Saheed
Old Oct 29, 2008 | 05:06 AM
Jobro's Avatar
SAE Junkie
I will give you my map.
Share CAR specifics and I will tell you what to change. If using standard primary injectors then boost Req_Fuel from 7ms to maybe 9-10 and that should get you started.
Old Oct 29, 2008 | 05:13 AM
Jobro's Avatar
SAE Junkie
Here is my map for a 12A street port with twin 50mm IDA throttle bodies, race style header collecting at gearbox. S5 Turbo 550cc Primaries, and 870cc secondaries.
Fan Relay output on IAC1A
Code Version is ms2extra1.0.2
File Type: zip
Old Oct 29, 2008 | 08:42 AM
Smokems's Avatar
I love my 13bT
Halfbridge setup with 820 primaries...(i have 550's available) and 1600 secondaries
Thanks Jobro for your information. really appreciate it.
Old Oct 29, 2008 | 09:18 AM
Aaron Cake's Avatar
Engine, Not Motor
Most street port maps will be way too lean.
Just generate a VE table with the engine constants dialog and the car should start on the default settings. Bridgeports require a LOT of fuel.
Old Oct 29, 2008 | 11:16 AM
Smokems's Avatar
I love my 13bT
ok thanks aaron
Old Oct 29, 2008 | 04:48 PM
Jobro's Avatar
SAE Junkie
I already told him to further enrich my map 30%, and it was only meant to get the car started.
Old Oct 29, 2008 | 11:58 PM
red_ricer's Avatar
Spending too much $$$
I have just about the same parameters to work with. Bridgeport, 820cc primary, 1600c secondaries, etc. I am looking to just start my car aswell. If you adjust the MSQ file, let me know if you can share it.
Old Oct 30, 2008 | 07:48 AM
Smokems's Avatar
I love my 13bT
will do ill let you know in a week
Old Oct 30, 2008 | 12:23 PM
red_ricer's Avatar
That would be awesome if you could do that. I am not a "tuner," I don't have enough knowledge/experiance with a full standalone to start messing with engine parameters.
Old Oct 30, 2008 | 01:34 PM
Jobro's Avatar
SAE Junkie
best start learning, but its not as hard as you may think! By feel I could get the engine AFR's inside the 12:1 to 17:1 region and I'm a total novice. WB02 is needed to get it spot on tho.
Old Nov 6, 2008 | 07:12 AM
Smokems's Avatar
I love my 13bT
alrighty.....soo we got the car started and idling at 1.5k....but since we didnt have no exhaust...and it was 4am in the morning...we got a noise complaint. For the person that wanted the map...ill post it later today. just woke up from 2 hours of sleep. feeling great...cant wait to go back to her but first got to drop her off at exhaust shop....
Old Nov 6, 2008 | 09:17 AM
red_ricer's Avatar
Awesome! You should post some videos of it as well!
Old Nov 6, 2008 | 11:57 AM
Smokems's Avatar
I love my 13bT
I will in just a sec....i have to wait for a friend to come back
Old Nov 10, 2008 | 05:55 AM
Smokems's Avatar
I love my 13bT
Hey i was wondering...usually what kind of timing does a halfbridge usually see. I have it currently set at 17 degrees advanced and its very rough during idle.... I figured maybe i can drop down to 12 maybe even 10 degrees advance...i just need some input from those who have a nice soft smooth idle. thanks
Old Nov 10, 2008 | 10:54 AM
Aaron Cake's Avatar
Engine, Not Motor
I run about 12 degrees at idle, 30 degrees at low RPM low load, tapering down to around 20 degrees at atmospheric (with a few more degrees added as the RPMs rise), around 15 at low boost, 10 degrees at high boost.
Old Nov 10, 2008 | 12:04 PM
2Lucky2tha7's Avatar
Back at it again!!
The 1st file is what I got his car was running on when I left that day. The 2nd file involves a few changes. The timing map is actually a slightly modified one based off of one that was copied from another forum member on here.....I believe it was a 12A bridge setup.
File Type: zip
Old Nov 10, 2008 | 01:38 PM
pmrobert's Avatar
My 12A street port idles very smoothly at 5ATDC (yes, that's after) verified by strobe. I have the map set to move that to ~10BTDC by 1200rpm or so. IMHO, idle timing is not an arbitrary number - each engine/setup/installation may need to be tuned by ear for best results.
Old Nov 17, 2008 | 03:08 PM
Smokems's Avatar
I love my 13bT
MD
i figured i'd post this and see if anybody can give me some feed back. Here is my current map on the MS as well as the Datalog with accurate date via Wideband. Thanks.
File Type: zip
Old Nov 20, 2008 | 11:52 AM
Smokems's Avatar
I love my 13bT
nobody has any input?
Old Nov 20, 2008 | 10:11 PM
lonewolfrx's Avatar
what kind of timing does a full bridge port usually see?
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
