single turbo bov problem.PLEASE HELP
Old Oct 28, 2008 | 09:16 PM
TAILWHIPPER's Avatar
Guys,
I recently purchased a synapse/sychronic bov from rx7store to go with my new single turbo setup.I was going to mount/weld it to the aluminium intercooler pipe just below the greddy compression tube (where I have seen most of the guys on the forum set up this way) but the weld on flange that came with it is stainless steel .I'm very dense on welding but as far as I know it ain't gonna happen!Is there a way around this or has anyone got this setup or can help as to how I can mount this???
Thanks.
Old Oct 28, 2008 | 10:00 PM
R-R-Rx7's Avatar
Rotor or no motor
order the aluminium flange
Old Oct 29, 2008 | 06:44 AM
That would help!Didn't know they did an aluminium flange.
Do you have this setup???
Old Oct 29, 2008 | 08:16 AM
R-R-Rx7's Avatar
Rotor or no motor
no i dont, i dont know if they make the alumunium flange but i would consider a very stupid move if they only made a stainless steel one. IF that is the case (which i doubt it) send some pics of the BOV and u might be able to match with another flange
Old Oct 29, 2008 | 10:09 AM
darkside7's Avatar
which flange did you choose with your BOV? You can get different types of aluminum flange for your BOV. ( IE Greddy or hks style)
Eddie.
Old Oct 29, 2008 | 02:33 PM
cewrx7r1's Avatar
Eye In The Sky
You need to do research befor buying equipment!
Old Oct 29, 2008 | 04:09 PM
On purchasing I said I was welding the bov to the intercooler pipe and this is the bov that was recommended to me.
Unfortunately the flange that arrived with the bov was stainless steel.
Didn't think I needed to order another flange coz it stated that it came with a weld on flange.
Old Oct 29, 2008 | 04:11 PM
Eddie.
Do these type flanges fit the synapse bov???
Old Oct 29, 2008 | 04:55 PM
Bacon's Avatar
IRS 4 Life
description on the rx7store
"Innovative Piston Actuated Design
Absolutely No Diaphragm
Pull-Type BOV designed to stay closed under boost
Detachable Re-Circulation Discharge and Interchangeable Flange
Includes Stainless Steel Weld-on Flange "
Either try to find a almnium flange or, get a SS intercooler pipe. www.burnsstainless.com
Old Oct 29, 2008 | 08:46 PM
darkside7's Avatar
yes. You need to make sure by looking at your BOV.
Old Oct 29, 2008 | 09:14 PM
mono4lamar's Avatar
In the burnout box...
You'll simply have to order an aluminum flange to match your BOV.
Old Oct 30, 2008 | 07:14 PM
Johny zoom's Avatar
stupid synapse poeple.... you could send the old no good thing to me..
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
