Sticking windows
Old May 14, 2002 | 06:19 PM
mwpayne's Avatar
Admitted 'rexaholic'
Sticking windows
This seems really trivial, but both windows on my 1985 rx7 are very difficult to roll up, and won't stay on the track. I sprayed some el cheapo silicone lube in the mechanism, this helped quite a bit. What lub is best for this, and is there anything I can do to keep these on the track?
Thanks!
Old May 14, 2002 | 07:16 PM
eddierotary's Avatar
back with rotaries
i have the same problem. i think is the window seal
Old May 14, 2002 | 07:29 PM
Johnny D's Avatar
I have the same problem and I'm thinking of buying new doors.
Old May 14, 2002 | 07:53 PM
RotorMotorDriver's Avatar
Seven Is Coming
I have a similar problem...Mine dont go down more than two inches, and then they will go up just fine...I think Im just gonna take the doors apart, take the regulators out nd silicone them all up like I did to my other ones and hope that helps.
~T.J.
PS - Ive heard silicone lubricant works best.
Old May 14, 2002 | 08:53 PM
jeremy's Avatar
male stripper
i have rollups and i have to do the up/down/up dance. i'm thinking about wheel greasing the mechanism and putting new plastic on the doors.
Old May 14, 2002 | 09:08 PM
i have electric/manual windows@@
i need one hand to press the switch and another hand to pull it up~~ then it's still can't close properly.
hahaha~~~
Old May 15, 2002 | 06:20 AM
DONNA's Avatar
the rubber that is in the window tracks was bad in mine too causing the window to act up, went to bone yard and found some that were in better shape, also i took the door panel off and drilled another hole where the forward vertical runner attaches, put a new hole about 1/2 inward and reattached that riser, now the window goes up/down and doesnt fall out anymore..took out some of the slack........
Old May 15, 2002 | 09:04 AM
85RX7GS's Avatar
I had the same problem with the glass coming off the track on my Jeep. I did something similar to Donna's method (drill a hole and put in a stopper on the track) and it worked great.
Old May 15, 2002 | 10:47 AM
Directfreak's Avatar
I am a Jeeper Now.
Previous Thread on Power Windows - and how to Fix them
DocHoliday89
Power FC Forum
11
Feb 18, 2018 01:35 AM
turbojeff
Oct 5, 2015 10:50 AM
