Center speaker, connection?
Old May 14, 2002 | 06:07 PM
gzon's Avatar
I have changed my old factory tape-headunit to a CD unit but then the Center speaker went out, How do I connect it? Has the center speaker its own amp or is it powered by the Tape-unit?
Thanks.
Old May 14, 2002 | 07:16 PM
Heath's Avatar
MAGNUM SE7EN
There is a center channel amp under the tranny tunnel cover (where your right arm rests) that I believe is for the center speaker.
Old May 15, 2002 | 04:46 AM
gzon's Avatar
How do I connect it to my new unit? somebody must have done that cause it really sucks without it.
Old May 15, 2002 | 04:57 AM
rotorbrain's Avatar
fart on a friends head!!!
that center channel speaker makes that much of a difference? i would cut the wires and spice it into your fronts. most aftermarket cd players dont have a center channel hook-up. so if you have an external amp for your fronts then you can hook up your centerchannel directly to your front wires.
Old May 15, 2002 | 07:12 AM
Enthu's Avatar
Still has an RX7.
just get component tweeters , and you'll forget your car ever had the center speaker. fill that space with a mickey mouse ear gauge pod.
Old May 15, 2002 | 07:26 AM
gzon's Avatar
I will change my speakers later in front to a component kit, but for now I thought I could connect the center to my unit, there must be a output signal from the oem tape-unit, the question is if its a low or high level signal,
Old May 15, 2002 | 07:43 AM
Enthu's Avatar
Still has an RX7.
yes, there is another output from the stock deck. low or High I couldn't tell you. the reason you don't see 5-channel systems anymore is beacause of phasing problems I hear, and a 6-speaker component just sounds better and allows greater imaging when compared to a 5. right now I have a 4 speaker set up, and it is not very noticeable that the center is gone center. only when I stick my head up on my steering wheel. and if you wanted to upgrade the center, you can get speaker out of a JBL home theatre pack, it's got the same size speaker in the center channel. I doubt it'd be worth the effort though...
Old May 15, 2002 | 10:35 AM
maxpesce's Avatar
Ex fd *****
The stock system was only 3 channels (Left, Right, Rear Subs) the center speaker amp is bridged off the front speakers - the rear speakers are Woofers only.
In the std system the fronts Is Bridged off the HIGH level Outputs from the head unit amp.
In the BOSE system the front is bridged off the low level outputs to the front (door mounted) amps. The Center amp (different & not interchangeable btw std & Bose system) is located under the dash to the right of the glovebox.
I have a center amp for the std (non BOSE) system for sale $25 shipped
Old May 15, 2002 | 02:00 PM
gzon's Avatar
I got the standard system so my center is then driven by the headunit? how do I remove the center so I can check wich cables thats connected?
Old May 16, 2002 | 03:03 AM
rynberg's Avatar
The center speaker is powered by it's own amp, but it is fed speaker-level inputs from the left and right. It's the same thing you would do if your head unit did not have line-level pre-outs.
If you are powering your speakers with the new head-unit, just run a left and right speaker-level feed to the center channel amp. If you are using a separate amp, you will have to run the left and right speaker-level feeds from the amp (unless the line-level and speaker-level outputs are both active at the same time on your head unit).
Old May 16, 2002 | 02:18 PM
gzon's Avatar
Thanks, I will try that.
Old May 16, 2002 | 05:44 PM
gzon's Avatar
Now I have changed my unit, I found no other cables to connect so I just connected it with my mazda-ISO adapter and now it works ok. But I dont know why it didnt work last time I tried. hmm..... Anyway, thanks for your time.
