Ultra sensitive throttle - barely touch pedal and goes to 2.5k
Old Oct 27, 2008 | 08:25 PM
jaydok's Avatar
Okay, so I have a bouncing idle. I've searched and searched and searched the posts, and most commonly seems to be a vacuum leak. So I've checked and checked and checked and can't find a vacuum leak. But in all this searching for a vacuum leak, I've noticed something else:
When I start the car from cold, it idles at 2.5 k for about 2-3 minutes. Once it warms up, it goes down to 900 RPMs, but then bounces from 900 to 1,500. If I so much as touch the gas pedal, it goes immediately to 2.5 K RPMs. There is no way to hold the RPMs at less than 2.5 K using the throttle. Also, every once in a while, the idle bounce goes away when there's no electrical load. But the minute I add any electrical load, the idle bounce starts.
So......bouncing idle aside, why can't I hold the revs at anything less than 2.5 K? Car runs fine otherwise.
Thanks for any help.
Old Oct 27, 2008 | 11:35 PM
IRPerformance's Avatar
Sponsor
Mods to the car? What is the condition of the throttle cable?
Old Oct 28, 2008 | 01:09 AM
jkstill's Avatar
Searching for 10th's
I think I would start by checking the TPS (throttle position sensor)
It's in the manual, and if you search there's a good writeup on doing this as well.
Old Oct 28, 2008 | 03:24 AM
SINxSELEKTAH's Avatar
Punkrockin JUNGLIST
how's your brake peddle? i've noticed this symptom when working on cars with a vacuum leak from the brake booster to the intake manifold. my fd did the same thing with an extremely stiff peddle & extremely poor braking performance. i popped the hood and noticed that the vacuum hose popped off cause i forgot to clamp down the hose.
Old Oct 28, 2008 | 06:48 AM
jaydok's Avatar
Thanks, i'll check TPS and brake booster
Mods are upgraded injectors, PFS intercooler, fluidyne radiator, PFS exhaust, blow off valve, computer with controller, turbo timer, and reliability mods.
Old Oct 28, 2008 | 07:17 AM
DaveW's Avatar
Racecar - Formula 2000
This may or may not apply, but check out this thread:
https://www.rx7club.com/showthread.p...lity+secondary
Old Oct 28, 2008 | 08:37 AM
Sponsor
What computer? A bouncing idle if often caused when the computer has one target idle set, but the throttle body is adjusted differently. The computer will try to get the idle where it is set but is unable to. An overly lean idle can also cause this.
Old Oct 28, 2008 | 10:04 AM
jaydok's Avatar
Apexi with power fc.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
Shainiac
Jul 17, 2019 02:20 PM
blackball7
34
Sep 16, 2015 10:10 AM
The1Sun
Sep 7, 2015 10:21 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
