Haltech LS1 coil diagram for e6k
Old Oct 27, 2008 | 09:50 AM
dznutzuk's Avatar
Uncontrollable drifter
Hey Claudio could you modify this picture(using paintbrush or whatever else) to clear up some problems on how to hook up 4 LS1 coils with the stock FD ignitor, thank you!
Old Oct 27, 2008 | 10:39 AM
fritts's Avatar
Mad Man
Check this thread out for more information on the coil pinouts
https://www.rx7club.com/showthread.p...&highlight=ls1
Leading gets branched to the the two leading coil inputs, Trailing outputs go to their respective coil
The stock igniter is not used, outputs come directly from the haltech.
Old Oct 27, 2008 | 08:36 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
You dont use the stock igniter as Fritts pointed out. With E6K in direct fire you will connect Ign.Out to both Leading coils, Dig1 to T1 and Dig2 to T2. Searching is your friend use it.
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
windom
Sep 11, 2015 04:48 AM
dillrx7
Sep 7, 2015 09:38 AM
BUSTN
V-8 Powered RX-7's
Sep 2, 2015 04:39 PM
