Rear wiper not working
Old Oct 24, 2008 | 10:28 PM
sbelyo's Avatar
Boosting to work
I just got my 93 FD and I can't seem to get the rear wiper working.
Should it move when I spray wiper fluid with the front wipers?
I can also move it with my hand, is this bad?
Old Oct 25, 2008 | 06:43 AM
dgeesaman's Avatar
If you can move it by hand the wiper gearing is not connected or broken somehow.
Fortunately I'd guess you can get a used gear/motor pretty cheap on the classifieds.
Old Oct 25, 2008 | 03:06 PM
camarols6's Avatar
i can move mine with my hand and it still works so i would check the fuse or check the contacts in the back because mine did the same thing.
Old Oct 27, 2008 | 10:29 AM
sbelyo's Avatar
Boosting to work
In that case it might be user error... should it come on when I squirt washer fluid on the front windsheid?
andyvideopro
Aug 11, 2015 09:16 PM
