Car starts, dies after couple of seconds...starts up fine after 5+ tries.
Old Oct 22, 2008 | 12:18 PM
CyberPitz's Avatar
Boost ahoy!
Title of thread is vague...but I'll try and help. NOTE, searching didn't really reveal anything helpful, and I'm sure it's been answered. Sorry for this..
The car will start right up just fine. it will rev up to 1.5kish then start to bog down and die. If I give it gas, it will die instantly. This will happen for about 5 times, then it will finally start up, gas works fine, it's great. Kind of confusing. Lucky for me the car doesn't flood.
87 TII is the car.
Old Oct 22, 2008 | 12:22 PM
thepoloplaya's Avatar
Fe3 FD
cold start, warm start or all the time?
Old Oct 22, 2008 | 01:08 PM
CyberPitz's Avatar
Boost ahoy!
Cold start
Old Oct 23, 2008 | 10:09 AM
CyberPitz's Avatar
Boost ahoy!
I don't know if this can be any helpful of information...
My car idles at around 600 RPMs according to the SAFC2, so I tried to raise the idle just a tad, and the BAC will not change a thing. Something tells me it isn't working, but that's one of the things that just kicked in my head that could be one of the culprits.
Old Oct 25, 2008 | 09:28 AM
CyberPitz's Avatar
Boost ahoy!
Awwww, come on someone
Old Oct 25, 2008 | 01:46 PM
HAILERS's Avatar
HAILERS
The water thermowax isn't set right. Read the FUEL AND EMMISIONS section of the FSM on HOW TO.
Plus, once the engine is HOT, pull the plug off the BAC while idling. Question: did the idle change?
Old Oct 27, 2008 | 02:52 PM
CyberPitz's Avatar
Boost ahoy!
I'm liking where this is going.
I will check on the thermowax possibly this weekend. As for the "plug" you're speaking of....are you saying unscrew the 'screw' on the BAC all the way?
Old Oct 27, 2008 | 02:57 PM
kontakt's Avatar
is The Whoopieschnootz
No, I assume he means the electrical plug. That will determine if the BAC was doing anything or not.
Old Oct 27, 2008 | 03:43 PM
CyberPitz's Avatar
Boost ahoy!
Ah, that is what I was thinking at first, but wanted to make sure :P
Also, the term"Water Thermowax" is something the FSM isn't familiar with, I'm assuming "Water Thermo Sensor" is the correct term for me to check out?
*EDIT* If it is indeed the Water Thermo Sensor that is the issue, where would I go to get another one besides making a WTB?
Old Oct 27, 2008 | 07:48 PM
Stanello's Avatar
backslash beanbagrace
The thermosensor is the green coolant temp sensor threaded into the back of the waterpump housing.
The thermowax is on the throttle body and maintains cold idle.
Old Oct 28, 2008 | 01:11 PM
CyberPitz's Avatar
Boost ahoy!
oh....I wonder why the FSM didn't say anything about it in the spot I checked out....I might have to look around a little harder! Thanks.
Old Nov 1, 2008 | 04:27 PM
CyberPitz's Avatar
Boost ahoy!
Alright, well slight update! The BAC isn't even plugged in at all, and I can't seem to find any power plugs for it. Looking at the Wiring Harness, I see a few snipped wires. Let's hope that none of those are the ones I need! Anybody want to show me where the plug is/color of wire for it?
Old Nov 1, 2008 | 05:28 PM
HAILERS's Avatar
HAILERS
Attached Thumbnails Car starts, dies after couple of seconds...starts up fine after 5+ tries.-water-thermowax.jpg
Old Nov 1, 2008 | 07:20 PM
CyberPitz's Avatar
Boost ahoy!
Dear god thank you. I scoured that damn FSM and for the life of me couldn't find it. I guess I'm more blind than I thought.
*waits for BAC plug info*
Old Nov 1, 2008 | 07:32 PM
HAILERS's Avatar
HAILERS
A car that does this when cold only, could have a problem with the plug on the water thermo sensor being off or the circuit is open to the ECU. Someone mentioned this above. A green plug on the back of the water pump HOUSING.
Old Nov 2, 2008 | 08:47 AM
CyberPitz's Avatar
Boost ahoy!
Well, I went outside in the dark with a little LED light trying to find some things, and I found the BAC plug at least! WOOHOO!
Battery died yesterday while doing it's little "Start/die" thing...hope I didn't maim the battery!
Old Nov 24, 2008 | 03:07 AM
younG_Gunner's Avatar
Re-Mama Mia!
Did you ever figure this out cause, it's REALLY similar to my problem.
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
gtcd
30
Aug 19, 2015 02:44 AM
smikels
Aug 18, 2015 01:26 PM
torky007
Aug 17, 2015 05:14 PM
