Haltech Voltage map
Old Oct 21, 2008 | 04:00 PM
Frostycrowd's Avatar
Voltage map
my car has a racing beat under drive pulley. It came with the car, I will probably put a stock pulley on in the future.
But anyhow my car when it is first started is not producing 14.5 volts it at first produces about 12-13v. I believe This is a combination of low idle during warm up and the pulley not turning the alternator quick enough. When its not producing enough voltage you can hear the fuel pump slow down and the car start to idle slightly goofy.
How should I start with the voltage map to compensate for low voltage rough idle.
Any help is appreciated.
Old Oct 22, 2008 | 09:09 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
I would recommend installing or controlling the BAC valve with the Haltech, it will allow you to increase RPMs for cold starts and compensate for other things like AC or power steering.
If you already have one, you might want to play with the settings to make the car fast idle when cold.
Old Oct 22, 2008 | 09:27 PM
AlexG13B's Avatar
brap brap brap
i couldnt get the stupid stock bac to work right. im thinking bout ditching it.
Old Oct 23, 2008 | 12:35 AM
BDC's Avatar
BDC
BDC Motorsports
+1.
B
BDC's Avatar
BDC
BDC Motorsports
Talk to me about it tomorrow, Alex. I'll help ya out. It's real, real simple.
B
Old Oct 23, 2008 | 10:39 AM
yea I probably should put a BAC in. I just have not looked much into, so I gotta figure how to wire it up.
Old Oct 25, 2008 | 08:59 PM
jacobcartmill's Avatar
just dont care.
FWIW, on my FC (e6k) i never got my stock s5 BAC valve to function 100% correctly. maybe i just had some whack settings.
i got it funtioning pretty much perfectly with my e8 on my FD though.
Old Oct 27, 2008 | 02:06 PM
I played with the voltage map and didn't notice much difference. I then played with the idle and leaned it from 12.5 to 13.0 AFR and it smoothed it out significantly.
When I was looking at all the maps I noticed my Priming map is rediculous and probably why it will flood out occasionally. it has 100+ms injector time at the lowest point in the priming map.
Old Oct 27, 2008 | 08:41 PM
EFI Tech Wannabe
Yeah Ted, the E8/E11 idle control is VERY good, but on the old K's and even with X's the best idle will come from using the stepper motor control wires with a 4 wire valve, either the Haltech/GM or something like that.
Old Oct 28, 2008 | 10:37 AM
could I get a idle control valve from some other car and make it work? One that does have the stepper control?
Old Oct 29, 2008 | 12:16 AM
EFI Tech Wannabe
Yes. Any 4 wire valve will be a stepper motor valve, Toyota Supra 2JZ/1JZ, GM vehicles, those are pretty good, you would have to custom fit them on but they should work well. The haltech unit is a GM style, and they sell the aluminum block with fittings so you can remote locate it and use some hoses to put air in the motor. They work pretty well and they have documentation for it.
Old Oct 31, 2008 | 01:55 AM
AnthonyNYC's Avatar
Stay tuned...
B
Hot min hot max baby!
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
WANKfactor
Sep 29, 2015 01:14 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
