Will a mechanical fuel pump work for a street EFI application?
Old Oct 21, 2008 | 11:41 AM
Chaotic_FC's Avatar
It is a very important question that i ask, because i have just come across a deal with a mechanical fuel pump included, which would be running it in a street EFI engine.
is there anyone here who actually has experience with street driven mechanical fuel pumps? I know it can be done, because on extremerotarys.com there is a kit for a mechanical fuel pump and it is on a EFI engine. but i dont know if it is possible to drive one on the streets, due to low RPM pressure and such things.
I have 5 days to know or i loose the deal
thank you in advance
Old Oct 21, 2008 | 04:01 PM
Chaotic_FC's Avatar
the reason why i ask is because it looks like i might buy this particular dry sump, and it has one attached to it:
it is a 3 stage pump, then the fuel pump, and on the back is a power steering pump.
Old Oct 21, 2008 | 05:55 PM
enzo250's Avatar
IRS Champion
actually the fuel pump is the last pump not the one in the middle..
And yes you can run it on the street. What kind of power/setup are you running on the street that would require a mech pump?
Old Oct 21, 2008 | 06:43 PM
Chaotic_FC's Avatar
whoops my mistake
i am about to begin my build of a peripheral port 13b with a 75mm turbo, and am looking for a dry sump for the engine. This dry sump just happened to have it bolted on, so it was convenient.
alphawolff
Nov 17, 2015 05:57 PM
