adjusting ignition timing
Old May 13, 2002 | 11:15 PM
suganuma's Avatar
no
this is probably a really stupid question, but maybe some other people dont know either....
i have a Haltech EMS that i got off of a friend's car and installed onto mine. When i start it up, I want to run a timing light on it to make sure that the ignition timing is the same for what the haltech says to what the engine is really seeing.....basically that both are dead on with each other the best i can get it.
my question/problem is: how do i adjust the timing (mechanically) so that if/when they do NOT coincide i can adjust it so they are the same....???
dont tell me to search around....i searched and got a headache and didnt really find anything to answer this.
thanks,
Old May 13, 2002 | 11:20 PM
P'cola FD's Avatar
Hamado things my way!
On the FD there is no way to adjust timing other than ecu modification.
Old May 13, 2002 | 11:22 PM
suganuma's Avatar
no
there has to be some way to adjust the crank pulley or what not to make sure that 0* on engine is also 0* for the haltech......
Old May 13, 2002 | 11:25 PM
P'cola FD's Avatar
Why do you think they aren't lined up?
Old May 13, 2002 | 11:28 PM
suganuma's Avatar
no
jsut trying to find reasons why engine went "KA-boom..."
its one of many possibly reasons i came up with....
and, when exchanging maps, it helps to have the timing on par and correct
Old May 13, 2002 | 11:35 PM
P'cola FD's Avatar
I haven't heard of the timing being mechanically adjustable before, but I'm not an expert either.
Old May 14, 2002 | 11:10 AM
luneytune's Avatar
Ther is no way to adjust mechanically without reworking the crank pulley/ encoder. Its all done in the ECU based on the fixed inputs provided by the crank angle sensor.
Old May 14, 2002 | 11:46 AM
suganuma's Avatar
no
exactly
so if you were to put the pulley on wrong or somehow have it set differently than another FD, then things "could" get all messed up and you could end up with different results and true timing at the engine.
smikels
Rtek Forum
May 12, 2016 12:34 AM
alphawolff
Nov 17, 2015 05:57 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
