What is this for?
Old Oct 20, 2008 | 08:13 PM
onefastrx712a's Avatar
What is this for?
Hope the picture works... I just got rid of my first gen and now have a 86 and im not sure what this is? can anyone help? Thanks in advance
Old Oct 20, 2008 | 08:29 PM
farberio's Avatar
NASA-MW ST4
Aux Port Actuator
Old Oct 20, 2008 | 08:40 PM
well thanks for the fast response farberio . can you elaborate a little more? what is it for? what will it do being broke like that? Thanks again .....
Old Oct 20, 2008 | 09:27 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
5th-6th port actuators- that whole unit that is attached to you LIM activates the 5th and 6th ports
is that a harness thats broken the picture sucks bad can you get any closer pics
Old Oct 20, 2008 | 09:50 PM
is this any better? I can see where it broke off at. So with it being broke in high speed it won't run right?
Old Oct 20, 2008 | 09:52 PM
well picture didn't work...
Old Oct 21, 2008 | 12:35 AM
RotaryRocket88's Avatar
Top Down, Boost Up
The broken part has nothing to do w/ the aux ports. That's one of the solenoids on the ACV. I think it's the split air solenoid, but you can check the FSM to be sure. You're not going to pass smog with it broken, but it won't do anything else.
Old Oct 21, 2008 | 07:06 AM
farberio's Avatar
NASA-MW ST4
^ Now that you mention it I do see the finger in the picture pointing to not the aux port actuator.
Old Oct 21, 2008 | 08:44 PM
Thanks RotaryRocket88 for the info. It's almost due for the inspection so I will need to fix it.
Old Oct 22, 2008 | 09:41 AM
Aaron Cake's Avatar
Engine, Not Motor
Uh, it's not an aux port actuator. The finger is pointing to the ACV.
FSM is in the FAQ.
