Turbo 2 clutch on N/A engine
Old Oct 20, 2008 | 06:12 PM
Rotaryterror's Avatar
i wanted to varify with someone else if its possible to use a turbo 2 clutch with the n/a 13b.would i have to just use the turbo 2 flywheel or is it no possible.if thats the case i have a s4 turbo 2 but my n/a engine is a s5. i feel like the turbo 2 oem clutch and pressure plate would be a little stronger and cost effiecient for right now thats why i would like to use this setup if possible. any help would be appriciated
Thanks
Old Oct 20, 2008 | 06:25 PM
RETed's Avatar
No.
Clutch disc needs to be matched to the transmission, specifically the transmission input shaft.
-Ted
Old Oct 20, 2008 | 08:34 PM
farberio's Avatar
NASA-MW ST4
You can use a turbo clutch on an n/a motor if you use:
Turbo trans, Turbo Flywheel, Turbo clutch and pressure plate, turbo release bearing, turbo clutch slave cylinder.
Then you will also need either a turbo driveshaft and turbo rear end or a turbo trans to n/a rear end driveshaft from mazdatrix or a custom made one.
Old Oct 21, 2008 | 06:01 AM
Turbonut's Avatar
Got to add, starter is also different.
Old Oct 21, 2008 | 06:51 AM
farberio's Avatar
NASA-MW ST4
Yup yup forgot about that, you should also put in a wire extension to the starter so you don't cause a fire like mine did.
cristoDathird
28
May 30, 2019 08:47 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
