Help a Friend....and a 13bt
Old Oct 20, 2008 | 05:00 PM
francogt1's Avatar
Lots of Hope
So my car smokes(out of the tail pipes) and im trying to figure out why
i'll try to explain everything good so its easier to understand.
*engine S4 13bt*
I need to figure out what might be wrong i have a cuple of ideas but not sure.
SIMPTOMS
*Car smokes after the engine is warm and its been rev'd you bring it up to 6k and then let it go down and it starts to smoke.
*oil smells like gas really strong/from dipstick.
*i have a HKS Piggyback Fuel/air Mixure Comp installed/ thinking it might smoke some because its really rich or Tuned that way.
*its White smoke smells really strong like gas.
it might be that the car is really rich, i can understand that, but if that's the case i just want to make sure that nothing elase might be causing the problem.
Guys Any feedback or help will be really aprishiated
Old Oct 20, 2008 | 05:23 PM
87 t-66's Avatar
not a drifter
coolant smoke is white and smells sweet. i would inspect the turbo. is there any oil in the intake or ic piping?
Old Oct 20, 2008 | 06:22 PM
francogt1's Avatar
Lots of Hope
duble post sry
Old Oct 20, 2008 | 06:23 PM
francogt1's Avatar
Lots of Hope
There is a bit of Oil yes in the rubber by were the clamp is. A while back i saw that so i just tighten them a bit with out thinkin anything of it.
What does this mean?
p.sIts the rubber going from the top of turbo.
Old Oct 20, 2008 | 06:41 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Any excess oil in the turbo compressor housing would be due to oil leaking past the seal. This will make it into the motor and be burned off, which would cause gray/white smoke.
A small amount of oily residue in the intake tract is normal though since the PCV system vents vapors from the crankcase into the turbo inlet duct (TID).
Old Oct 20, 2008 | 06:47 PM
francogt1's Avatar
Lots of Hope
ok makes sence How bas is this?
, btw the Smoke is white but dosent smell like coolant so by no mean smells sweet.
It smells very very rich in fuel. and like i said it mostly smokes after its been rev'd
Old Oct 20, 2008 | 08:37 PM
francogt1's Avatar
Lots of Hope
anyone ealse have any ideas?
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
BLUE TII
Sep 26, 2015 10:12 PM
Rx7supra
Mar 18, 2002 07:28 PM
