Does mazda make any aftermarket plug wires?
Old Oct 20, 2008 | 12:07 PM
rotaryking22's Avatar
Talking Does mazda make any aftermarket plug wires?
Need spark plug wires!!
I already changed my plugz 2 NGk!
Need opinions on spark plug wires. I heard accel was a good source!
Old Oct 20, 2008 | 12:17 PM
87 t-66's Avatar
not a drifter
stock wires are good. i use MSD wires and they are also seem to work well.
Old Oct 20, 2008 | 12:39 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
Oem Ngk
Old Oct 20, 2008 | 12:53 PM
S4GXL's Avatar
NGK or RE-A or racing beat or mazdatrix
Old Oct 20, 2008 | 12:54 PM
87 t-66's Avatar
not a drifter
mazdatrix makes spark plug wires
Old Oct 20, 2008 | 02:03 PM
Boosted11's Avatar
Pistons are gay
Just get ngk's, you can get them from most auto parts stores.
Old Oct 20, 2008 | 02:53 PM
J Wind's Avatar
http://www.mazdatrix.com/ign-3.htm its the 2nd up fro the bottom of the page. comes in your choice of red,yellow, blue, purple
Old Oct 20, 2008 | 02:56 PM
S4GXL's Avatar
mazdatrix is the ****
Old Oct 20, 2008 | 09:39 PM
Pinfield357's Avatar
i put Magnacore wires on everything i own
Old Oct 20, 2008 | 10:33 PM
jmkogut's Avatar
Magnacore ftw.
A good source of Mazda OEM parts is Mazdatrix.com, they sell a lot of brand new, kickass parts. The only problem is, Mazdatrix is really, really expensive compared to anything. but sometimes they just have stuff nobody else stocks. Next time check 'em out.
Old Oct 21, 2008 | 05:44 AM
Turbonut's Avatar
Plug wires are plug wires, as you'll see no performance gains with any, unless you're old wires are shot. So if money is a problem buy an inexpensive set, but if not, buy Magnecor.
Old Oct 21, 2008 | 02:22 PM
Talking rotaryking24
im guessing better spark 4 my car cuz it has weak spark!!!
Old Oct 21, 2008 | 03:24 PM
pistones's Avatar
plug wires are Not plug wires! it's not so much the performance gain from one brand to another but build quality and fitment. i want you to compare a pep boys wire to an NGK set, there is a huge difference. most of the cheaper wires pull apart easily and the shielding is crappy. i don't like using crap parts then wonder why my car runs funny.
Old Oct 21, 2008 | 10:21 PM
alexdimen's Avatar
TANSTAFL
Hmmm... that's a tough one.
Old Oct 21, 2008 | 10:56 PM
blackedoutFC3S's Avatar
HKS obsessed
I run Mazdatrix and so do most of my other FC buddies. They're cheap and great, 50 is cheap for what they are.
Old Oct 21, 2008 | 11:04 PM
psychotic7's Avatar
NGK....they make the best plugs and the best wires....bottom line
Old Oct 22, 2008 | 05:48 AM
Turbonut's Avatar
Never mentioned construction, but if you're pulling apart a plug wire during removal, then you had better take some lessons as how to remove the wires from the plugs. Guess you're one of the guys that gets ahold of the wire itself and gives it a pull and wonders why they seperate. Ever hear of a spark plug wire removal tool? Guess not.
Also, if you're car runs crappy on one good set, it will run crappy on another. Better check the Magnecor website and you will see that new wires will not change the performance of the vehicle unless the old wires were failing. Guess you had a bad set from pulling them apart.
Old Oct 22, 2008 | 01:34 PM
rotaryking24
thanks its a big help!!
So what would b a good size 8mm 0r 10mm?
Old Oct 22, 2008 | 10:18 PM
psychotic7's Avatar
Stock 8mm is more than enough
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
PhillyFC
Aug 21, 2015 06:36 PM
elfking
Aug 19, 2015 09:48 PM
