engine start up problem
Old Oct 19, 2008 | 02:26 PM
NotoriousKracka's Avatar
I have a 94 fd with 60k I was on a suspended liscense for a year and was not able to start the car as frequently as I wanted too. It flooded a few months ago and we changed the spark plugs for ngk 9's all around and got a walbro racing fuel pump. I gassed it up today and it still won't start what's the problem
Old Oct 19, 2008 | 02:38 PM
Mahjik's Avatar
Mr. Links
Did you actually go through the de-flooding process, or did you only replace the spark plugs?
Old Oct 19, 2008 | 03:14 PM
Just replaced the plugs..looked for the deflood process online but was unsuccessfull can u explain it to me
Old Oct 19, 2008 | 03:43 PM
Mahjik's Avatar
Mr. Links
Arrow
http://www.fd3s.net/starting_flooded.html
Old Oct 19, 2008 | 04:55 PM
DaveW's Avatar
Racecar - Formula 2000
How old is the gas? Is it from over a year ago? You may have to drain and put fresh in if it is that old.
Old Oct 19, 2008 | 05:05 PM
Put in new premium gas and tried the deflood process twice with no luck...it spits thick white smoke out and sounds so close to starting but won't roll over
Old Oct 19, 2008 | 06:44 PM
Could the fuel filter be clogged because of the bad gas sitting in the car?
Old Oct 19, 2008 | 11:11 PM
Just removed the fuel filter and it was not clogged I'm going to replace it anyways due to the new fuel pump it's always smart to change both. But there is still no obvious fix it still won't start any advice?
Old Oct 20, 2008 | 08:25 AM
Mahjik's Avatar
Mr. Links
Check if you have fuel and spark, then you just need to keep going with the un-flooding procedure. It can take a a few attempts if the car was flooded and not started for a while. Also make sure you keep a battery charger on while doing this process. You can run the battery down VERY easily while trying to get it started.
Old Oct 21, 2008 | 04:06 AM
wack0aznboi's Avatar
make sure to properly gap the spark plugs.
Old Oct 21, 2008 | 01:17 PM
jbust's Avatar
13BREW
try to apply some ATF (automatic tranny fluid) on the tip of the clean spark plugs. if you get it to start you would get alot smoke for a meantime (due to the atf) but this will go away as the car warms up. hope that helps.
Old Oct 22, 2008 | 03:32 AM
farkmedead's Avatar
[quote]Quote:
Check if you have fuel and spark, then you just need to keep going with the un-flooding procedure. It can take a a few attempts if the car was flooded and not started for a while. Also make sure you keep a battery charger on while doing this process. You can run the battery down VERY easily while trying to get it started.[quote/]
yep,. keep trying the de-flood...if it's not that then *shrug
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
befarrer
Aug 14, 2015 04:18 PM
