Splicing Question
Old Oct 18, 2008 | 04:17 PM
WhiteRabbit's Avatar
Splicing Question
I have a bad connector on my driver side window and I want to replace it with another connector that I pulled off of a donor harness. I've never spliced wiring before, so where do I start and what is the safest and most efficient method to do so? I have to get this window down.
Old Oct 18, 2008 | 04:59 PM
87 t-66's Avatar
not a drifter
cut both plugs off, leave a little wire on the new connector, solder them together and shrink wrap over the solder (i forget what the covering is called). you heat it and it will shrink down and cover the spliced wiring.
Old Oct 18, 2008 | 07:08 PM
HAILERS's Avatar
HAILERS
Heat shrink Tubing that can be had at RadioShack or Home Depot maybe. Slip it on the wire BEFORE you solder the two pieces together. Just in case.
Old Oct 18, 2008 | 09:58 PM
incubuseva's Avatar
Boost knob
Get a wire plug puller tool. It has a bunch of prongs on it. You find the right prong, stick it in the back side of the plug where the wire goes into the plug, then pull the wire right out. Then put your new wire in there + you can use the same plug.
Or do the solder, shrink wrap routine. That works too.
Old Oct 18, 2008 | 10:09 PM
HAILERS's Avatar
HAILERS
Oppps. My bad. Yeah. If your just replacing the plastic plug, you can depin all the wires in the present plug and install them in the new plug. You can use something like a jewlers common screwdriver to depress the plastic tongue in the sockets of the plug, and at the same time pull the wire out. No cutting required. Sorry 'bout that.
Old Oct 18, 2008 | 11:40 PM
incubuseva's Avatar
Boost knob
Yeah that's what it's called. I couldn't think of the correct name.
Old Oct 19, 2008 | 11:20 AM
Where can I pick up one of these tools? Is it possibly an autozone kind of thing?
Old Oct 19, 2008 | 11:52 AM
87 t-66's Avatar
not a drifter
a very small screwdriver or punch might work.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
