Just swapped s5 vert motor into s5 coupe. Wont run. What is this wire?
Old Oct 18, 2008 | 02:55 PM
Dltreezan's Avatar
My Bick is Digger
Arrow Just swapped s5 vert motor into s5 coupe. Wont run. What is this wire?
Hey guys,
I did the swap from the s5 vert into my s5 coupe so I can sell it. I connected everything like I was supposed to but there are a few issues I am having.
There is a small difference on the ECU as the coupe has a n351 whereas the vert is an n352. This is no problem as it seems from searching on it.
However I have found this wire which runs through the engine bay and disconnects near the ECU. I assume this is the cruise control wire and it looks like it went to the relay in the engine bay on the ver as the coupe does not have cruise control.
Can you guys confirm for me?
[URL=http://g.imageshack.us/img511/p1010388zj4.jpg/1/][IMG]
Old Oct 18, 2008 | 03:06 PM
Dltreezan's Avatar
My Bick is Digger
now I also have another problem when I try to crank it up. It turns over fine but it seems like it isnt getting any fuel. I put gas in it and also noticed that the injector plugs kept clicking over and over rapidly. There is something that is missing that I didnt do that is obvious and I cannot figure it out.
Here is the pic of what is making all of the clicking.
[URL=http://g.imageshack.us/img217/p1010389jl6.jpg/1/][IMG]http://img217.imageshack.us/img217/p1010389jl6.jpg
Old Oct 18, 2008 | 03:20 PM
certifiednut's Avatar
Mike Honcho
those things in the picture are vaccum solenoids. Check to see if you are even building fuel pressure, then if you do, check to see if you are getting spark. Also make sure the plug on the front of the afm on the bottom of the airbox is plugged in.
Old Oct 18, 2008 | 03:31 PM
Rob XX 7's Avatar
FC guy
the vert harness will also have wiper harness in it- at least s4 verts do.
Old Oct 18, 2008 | 04:41 PM
Dltreezan's Avatar
My Bick is Digger
why are they clicking then?
Old Oct 18, 2008 | 04:48 PM
87 t-66's Avatar
not a drifter
first pic is for the air bags
Old Oct 18, 2008 | 04:50 PM
Dltreezan's Avatar
My Bick is Digger
what ant the vacuum sloenoids?
Old Oct 18, 2008 | 05:04 PM
87 t-66's Avatar
not a drifter
wat
Old Oct 18, 2008 | 06:44 PM
Dltreezan's Avatar
My Bick is Digger
sorry man i was using my lil bros iTouch. What about the solenoids? What causes them to click like that?
Old Oct 18, 2008 | 11:47 PM
Dltreezan's Avatar
My Bick is Digger
ok guys what is that rapid clicking noise coming from in that pic? What would cause it to do that?
Old Oct 19, 2008 | 12:44 AM
Marv's Avatar
could be flooded,check if plugs fire and make sure fuel is going into engine.
These cars are frustrating.
Old Oct 19, 2008 | 01:06 AM
Dltreezan's Avatar
My Bick is Digger
all that could be true but i still need to know what this rapid clicking sound is coming from those colored plugs.
Old Oct 19, 2008 | 03:13 AM
jerd_hambone's Avatar
Do you have a spark plug wire off at the coil?
They will make a clicking noise which is really an arc jumping from the coil to the body
Old Oct 19, 2008 | 09:06 AM
scrip7's Avatar
Rotary Gearhead
The blue-wrapped harness with the red and blue connectors in the first pic connects to the Antilock Brake unit on cars that came equipped with it. The connectors on the other end of the harness (next to the ECU) are supposed to connect to the ABS control unit. Your car doesn't have ABS so these connectors aren't used.
Check to make sure all your grounds are there and clean and tight. Is the ground wire from the firewall tab to the top of the tranny connected?
Old Oct 19, 2008 | 09:35 AM
87 t-66's Avatar
not a drifter
no. no. no. they are for the airbag on a s5 vert. i already said this.
i can't really help with the rats nest thing as i threw that stuff away a long time ago.
Old Oct 19, 2008 | 11:32 AM
Dltreezan's Avatar
My Bick is Digger
so nobody has any idea why these things would be clicking. nothing else is clicking. it is the rats nest.
Old Oct 19, 2008 | 11:49 AM
Rob XX 7's Avatar
FC guy
they could be clicking because they are bad or getting a bad signal.
Logically speaking when a solenoid clicks its because its not functioning or getting a signal it does not agree with.
Old Oct 19, 2008 | 02:22 PM
Dltreezan's Avatar
My Bick is Digger
hmm. so i should take the ecu out from the vert and try it in the coupe since that is the motor it came with?
Old Oct 19, 2008 | 02:33 PM
teddyrx2's Avatar
One Luv "Till The End"
+1
Old Oct 19, 2008 | 03:13 PM
Dltreezan's Avatar
My Bick is Digger
well I know they are not bad because i drove the other car a few days ago with that engine just fine. Only when i swapped it is it doing any of this....
Old Oct 20, 2008 | 03:05 PM
Dltreezan's Avatar
My Bick is Digger
bump
Old Oct 20, 2008 | 03:16 PM
dot_txt's Avatar
My car hates me
Swap the ECU. See what happens.
Old Oct 20, 2008 | 10:05 PM
Dltreezan's Avatar
My Bick is Digger
ok i changed the ecu and it still clicked a little bit but i also noticed i was missing a ground on the tranny from the starter harness. I connected it as well as another plug but there is still another plug that I dont know where it goes. I will post a pic
Old Oct 21, 2008 | 05:30 PM
Dltreezan's Avatar
My Bick is Digger
t
Old Oct 21, 2008 | 07:31 PM
Dltreezan's Avatar
My Bick is Digger
the sire in the middle is the one that is not connected
