Does this clutch disk need replacing?
Old Oct 18, 2008 | 12:09 AM
apeiron
I have the engine out and not sure if this clutch needs to be replaced or not. If it does, what is the best street setup for 400-500hp and who has the best prices?
Attached Thumbnails Does this clutch disk need replacing?-clutch1.jpg   Does this clutch disk need replacing?-clutch2.jpg   Does this clutch disk need replacing?-clutch3.jpg   Does this clutch disk need replacing?-clutch4.jpg
Old Oct 18, 2008 | 10:38 AM
IRPerformance's Avatar
Sponsor
Clean out the slots between the pads. Looks like there is a lot of clutch dust built up. Judging from the rivets, there is still some life left but it is definitely past half worn. If that is a stock clutch there is no way it will hold the power you are looking for.
Old Oct 18, 2008 | 12:19 PM
MyRedFD's Avatar
Enter Title Here
I would replace it now since you have it torn apart already and with as worn as it is, and as he said if you're going for that kind of power, upgrade time.
Old Oct 18, 2008 | 01:38 PM
Mahjik's Avatar
Mr. Links
Twin plate setup: http://www.rx7store.net/product_p/exedytpfd.htm
Old Oct 18, 2008 | 02:32 PM
Obie2kenobe's Avatar
Nice moccasins.
Old Oct 18, 2008 | 03:07 PM
apeiron
Originally Posted by Obie2kenobe
Nice moccasins.
Thanks! They are Mephistos --- probably the most comfortable spinnakers you can buy in my opinion, they are worth their weight in gold.
Old Oct 20, 2008 | 09:52 PM
Do they have the rubber soles in em?
Old Oct 20, 2008 | 10:08 PM
apeiron
http://www.mephistoshoes.com/store/c...r-Men-p-2.html
I get a new pair every 3 - 4 years, they are the only shoes that dont get smelly if I wear them without socks.
Old Oct 21, 2008 | 02:49 PM
WHTEVO's Avatar
It looks like it still has a bit of life left but clutch discs aren't very expensive so i would just replace it while i was in there.
Aaron
Old Oct 21, 2008 | 03:05 PM
apeiron
Decided to go with a bones street comp clutch from rx7.com, I heard good things about it from a trusted source and I needed to upgrade to something with a bit more grip for the numbers I will be making.
streetlegal?
Mar 17, 2022 02:46 PM
alphawolff
Nov 17, 2015 05:57 PM
sYnth.
Aug 19, 2015 06:27 PM
