Need Help Setting Up Tps?
Old Oct 17, 2008 | 02:51 PM
illtakeyochik's Avatar
187 RX7 Gone To Heaven
I just finished my microtech install and its all working properly. i just need help on how to set up the tps (not install it) but how do i get the throttle to push it in and out correctly?? should i remove all the throttle things and move it to the other side? or do i leave it where it is and find a way to get it to push the tps in and out
Old Oct 17, 2008 | 11:59 PM
HAILERS's Avatar
HAILERS
I'm just curious. What changed on the TPS?
Why does the install of a MicroTech change the functioning of the normal series five TPS?????
Old Oct 20, 2008 | 10:16 AM
nothing it sits in the same place is just that the lil arm that pushes the tps in and out wont stay in place. so its not pushing it in and out accurately.. that side of the throttle has alot of slack and im new to the microtech stuff. i just figured i had to take some things off the throttle body
Old Oct 20, 2008 | 10:18 AM
Hazard15301's Avatar
Rotor Junkie
Search. There are dozens upon dozens of threads about this topic.
Old Oct 20, 2008 | 10:53 AM
HAILERS's Avatar
HAILERS
NO there are not dozens and dozens of threads with this problem. I can only guess, but it seems the throttle linkage is loose and flopping around. Got me. Make sure the TPS's bolts are snug. There shouldn't be any flopping around.
Take a picture of what your talking about. It's not clear just what is loose.
Old Oct 22, 2008 | 08:19 AM
ok i will
Microtech
30
Apr 23, 2016 06:37 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
