88 n/a gxl vacuum issues.
Old Oct 17, 2008 | 12:09 PM
tigerboy rei i's Avatar
Only RX7 for miles!
I don't think I labeled this right before. I'm going to try this again, in hopes that someone replies.
So I was looking at the write-up from rotary ressurection about removing the emissions. I thought this would be mostly good for me, as I've already removed the ACV and the EGR so I started into it. However, I really want to keep the thermowax, fast idle cam, BAC, and whatever else goes into the upper intake/throttle body, as I do run this car in winter and would like the ease of driving it will provide. I really want to remove the AWS and vacuum rail, though. Do any of these things need those vac. solenoids that are on it, or can I just hook them into engine vacuum? If not, which vac. lines do I actually need to cap and which need should I route to where?
Old Oct 17, 2008 | 01:36 PM
S4GXL's Avatar
^+1
im at exactly the same point this guy is with the same car. time to clean up the engine bay a little bit.
Cuzzynz
141
May 28, 2020 09:23 AM
mulcryant
Sep 9, 2015 05:24 PM
Frisky Arab
Sep 4, 2015 06:17 PM
