ATF fluid differences
Old May 13, 2002 | 06:11 PM
Chemical's Avatar
I'm planning to do the ATF treatment, does anyone know the differences between brands and types?
Most of them say Dexron III, Mercon or Type A...etc etc
Is this safe to use?
T.I.A.
Old May 13, 2002 | 06:18 PM
jeremy's Avatar
male stripper
cheap suff works fine. don't dump $$$ on it.
Old May 13, 2002 | 06:22 PM
Pele's Avatar
Right near Malloy
The main difference in each is friction modifiers for the clutch packs in auto trannies. You're just interested in the detergent properties for cleaning the valve bodies on the autotrannies. Each should have plenty of detergents. You could care less which friction modifiers are in it unless you're using it in a *****-matic transmission.
Old May 13, 2002 | 06:26 PM
jeremy's Avatar
male stripper
since he's using it for the atf treatment i don't think friction modifiers are all too important to him.
Old May 13, 2002 | 09:14 PM
Chemical's Avatar
Gotcha, thanks guys
exactly what I needed to knw
Old May 14, 2002 | 05:42 PM
ghetto-rx7's Avatar
can any one give me step by step instructions for the "ATF" treatment. He's talking about the thing were it gets in the rotors and burns all the carbon or somtin. i dunno but i would like to.
Old May 14, 2002 | 06:29 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
HAHA! That's a good one =P
But... What's the difference between using MMO and ATF for the treatment? I would imagine the ATF has more detergents than MMO does... And I know that MMO will not foul up the plugs like ATF will...
Old May 14, 2002 | 09:00 PM
jeremy's Avatar
male stripper
run a search on atf in the first gen section and you will come up with everything you should need.
Old May 14, 2002 | 11:22 PM
ghetto-rx7's Avatar
but "ATF" only has 3 letters lol
i tried 1st if it means n/ething
Old May 14, 2002 | 11:24 PM
ghetto-rx7's Avatar
i no
ill search automatic trassmision fluid!!!
k
ill try then ask if i dont get it
Old May 15, 2002 | 01:10 PM
jeremy's Avatar
male stripper
https://www.rx7club.com/forum/search...der=descending
this should do it
Old May 15, 2002 | 01:15 PM
ghetto-rx7's Avatar
k thnx
dradon03
Sep 18, 2015 05:57 AM
Evan Kurtz
Sep 13, 2015 08:40 PM
The1Sun
Sep 7, 2015 10:21 PM
Frisky Arab
Sep 4, 2015 06:17 PM
