5th gear acting sketchy
Old Oct 14, 2008 | 02:01 PM
SuphaG's Avatar
So sometimes when I'm driving I'm not able to get into 5th gear. It'll go all the way to the right, but when I'm pushing up it feels like it's hitting something. This only happens once in a while. Sometimes it will work and other times it won't. All the other gears go in fine.
I've already tried cleaning out the shifter area to see if any junk was in there jamming it. Also took out the detent ball, cleaned it and regreased the area with white lithium grease. Any ideas? Thanks!
Old Oct 14, 2008 | 02:04 PM
2slow4stock's Avatar
The waiting game......
Well i've always had problems with 5th on rx7's transmissions. I guess its there weak 5th gear or syncro? Or its just me. I just don't mind it anymore.
Old Oct 14, 2008 | 02:16 PM
Gene's Avatar
10 lb. boost, 5lb. bag
All my syncros are shot. Learn to double-clutch and you'll have no problems no matter how bad a box you're driving. It will make you a better driver too.
Old Oct 14, 2008 | 02:30 PM
HAILERS's Avatar
HAILERS
Plastic trash in the shifter. Remove the shifter and dig it out and replace the broken plastic parts. See MAZDATRIX's FAQ for shifter parts.
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
