fpr install
Old Oct 14, 2008 | 11:15 AM
the7kid's Avatar
fpr install
if i were to install a adj. fpr on an 87 tII do i need to remove the stock fpr. if you do need to remove it to run an adj. fpr inline what have other people done to bypass it.banjo bolts, weld something on, ect.
Old Oct 14, 2008 | 11:16 AM
87 t-66's Avatar
not a drifter
i used s4 rails and welded AN fittings to the ends. removed the stock fpr and PD and installed aftermarket units.
Old Oct 14, 2008 | 12:10 PM
the7kid's Avatar
the stock s4 turbo secondary rail is threaded on the fpr end right. does anybody know what thread size or pics and list of the parts you used for your setup
Old Oct 14, 2008 | 12:20 PM
87 t-66's Avatar
not a drifter
hope this helps... https://www.rx7club.com/2nd-generation-specific-1986-1992-17/post-pics-your-stainless-steal-fuel-system-556426/
all those fittings are pretty expensive. you could probably get away with using brass NPT fittings if you really wanted to.
Old Oct 14, 2008 | 01:29 PM
the7kid's Avatar
with the setup that they show on fc3spro do you have run an fittings all the way to the tank because i just want to bypass the stock fpr. i have no need to run a parallel fuel system. i was just thinking of drilling the sleeve out that slides up and down in the fpr until it doesnt interfere with flow anymore and then just jb weld the vaccume nipple closed or something like that. sound like it would work?
Old Oct 14, 2008 | 02:01 PM
87 t-66's Avatar
not a drifter
you can run it to the hard line by the stock fuel filter if you dont want to go all the way to the tank.
Old Oct 14, 2008 | 05:19 PM
the7kid's Avatar
any cheaper alternatives like a banjo bolt to replace it?
Old Oct 14, 2008 | 05:22 PM
87 t-66's Avatar
not a drifter
sure but you are still going to need the fittings for the FPR.
out of curiosity, why do you think you need an aftermarket FPR?
Old Oct 14, 2008 | 08:03 PM
the7kid's Avatar
dont need one my stock one is bad and its either by aftermarket(65.00) or stock new (118.00). i got a walbro to go in and im goin gt35r 1600cc secondaries and power fc over the winter so why not now. The megan fpr has nipples at each end not an fittings so it would go to the stock lines. stock lines are good for like 500hp and i wont be getting that. so it would pretty much be a waste of money for me to spend all that $.
Old Oct 19, 2008 | 05:59 PM
the7kid's Avatar
installed my new stock fpr and stock pump and i still have a slightly glowing turbo after a quick run down the street and back under no boost. im stuck. what should i check?
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
t-von
Sep 10, 2015 01:56 PM
vmerino
Sep 5, 2015 11:26 AM
