Microtech maps for 550 primary and 1000 secondary
Old Oct 14, 2008 | 06:23 AM
taz8924pr's Avatar
taz8924pr
I need maps for 550cc in primary and 1000cc in secondary,my engine is street ported,T04(60-1)turbo,walbro fuel pump,aeromotive fuel reg.
Old Oct 5, 2009 | 02:44 AM
SAVANT's Avatar
I SMELL GAS
bump...and i know its a old thread
Old Oct 5, 2009 | 04:08 AM
SAVANT's Avatar
I SMELL GAS
Rx72c please help your highness.....................
Old Feb 10, 2010 | 12:14 PM
RotaryEvolution's Avatar
Sharp Claws
see my reply in the other thread.
Old Feb 10, 2010 | 01:22 PM
SmogSUX's Avatar
No money. No love.
Prolly a similar map as mine..see Karack's reply lol he tuned my car
Old Feb 22, 2010 | 04:26 AM
bumpstart's Avatar
talking head
heres my generic map for mild port with 1000 secs
has proven safe up to around 16 psi
staging value and mix trim may change by as much as 5 % depends on the primary injectors used
( some latency differences between high and low ohming injectors )
normal disclaimers apply,, be sure your fuel system and voltage systems is up to it
be sure you understand that the -5 mark of the s4/5 pulley is used as datum zero and all values are relative to -5 ATDC
( ie,, 30 set in T max equates to 25 BTDC )
as is this staging value at 78% is to suit s5 550 saturated style primary injectors
with peak hold early s4 injectors you may find staging smoother with values down towards 72 %
be aware staging % effects the fuel map PRESTAGING and so changing its value down will lean the point just prior to staging
Originally Posted by bumpstart
-5 ATDC datum mark is 0 static timing
timing max=30 ( 25 BTDC )
mixtrim=5%
staging 78%
staging thresholds 2 psi , 3000 rpm
RPM WOT =3 PSI
RPM CRUISE=-9"hg
idle maps
-25=1.19
-20=1.19
-15=1.48
-10=2.38
-5=3.33
0=3.50
loadmaps
-25=1.38
-20=1.38
-15=2.43
-10=2.90
-5=3.33
0=3.50
2=3.62
4=3.90
6=4.10
8=4.57
10=4.95
14=5.95
16=6.33
18=6.95
20=7.95
WOT
1k=5%
1.5k=10%
2K=5%
2.5k=5%
3k=5%
3.5k=5%
4k=5%
4.5k=5%
5k=5%
5.5k=5%
6k=5%
6.5k=5%
7k=5%
7.5k=5%
8k=5%
8.5k=5%
9k=5%
CRUISE
1.5k=-20%
2k=-25%
2.5k=-25%
3k=-25%
3.5k=-20%
4k=-15%
4.5k=-15%
5K=-10%
5.5k=0%
T map
idle=0
-25=7
-20=6
-15=5
-10=3
-5=2
0=1
2=0
4=-2
6=-4
8=-6
10=-8
14=-13 ( -12 )
16=-16 ( -14 )
18=-18 ( -16 )
20=-20 (-18 )
T RPM
idle =10
1000=10
1500=14
2000=20
2500=22
3000=24
3500=24
4000=24
4500=24
5000=24
5500=24
6000=26
7000=26
8000=26
9000=27
split
idle=15
1k=15
1.5K=15
2k=14
2.5k=12
3k=10
3.5k=8
Old Feb 22, 2010 | 11:28 PM
drifting in drifting's Avatar
How about same mods just 720 1000s ?
Old Feb 24, 2010 | 10:26 PM
Sharp Claws
shouldn't matter, because you can't rely on other people's maps to be 100% correct for your car and setup. it's just a starting point!
Old Feb 24, 2010 | 10:33 PM
yeah just lazy i guess
Old Mar 3, 2010 | 05:20 PM
rx72c's Avatar
Top Answer: 1
Try this for 720/1000
Idle Map
Screen 1
30" ~ 1.38
25" ~ 1.48
20" ~ 1.33
15" ~ 1.71
10" ~ 2
05" ~ 2.1
00" ~ 2.56
2-20psi ~ 4.95
Load Map
Screen 3
30" ~ 0.95
25" ~ 1.19
20" ~ 1.33
15" ~ 1.71
10" ~ 2.14
05" ~ 2.57
00" ~ 3.56
2psi ~ 2.9
4psi ~ 3.9
6psi ~ 4.7
8psi ~ 5.1
10psi ~ 5.6
14psi ~ 6.2
16psi ~ 6.8
18psi ~ 7.4
20psi ~ 8
RPMwot Map Screen 17
5000 ~ 05
5500 ~ 08
6000 ~ 08
6500 ~ 10
7000 ~ 11
7500 ~ 11
8000 ~ 11
9000 ~ 12
The rest are zero
RPMcrs Screen 18
1000 ~ -12
1500 ~ -11
2000 ~ -12
THe rest are zero
Pump Map
Screen 19
Pump2Start ~ 2000
Pump1Amt ~ 00
Pump1Pulse ~ 04
Pump1Trig ~ 18
Pump1Stop ~ 00
Pump1Adv ~ 05
Pump2Time ~ 10
Pump2Amt ~ 30
Pump2Trig ~ 16
Pump2Stop ~ 00
Pump2Adv ~ 05
PumpDwell ~ 3.00
PumpTimers ~ No
Pump1Sync ~ No
PumpSpare ~ 00
PumpCold ~ 00
Water Map
Screen 20
-25 ~ 0
-17 ~ 70
-9 ~ 60
-01 ~ 50
05 ~ 45
11 ~ 45
18 ~ 42
24 ~ 34
31 ~ 26
38 ~ 24
46 ~ 19
60 ~ 12
68 ~ 06
82 ~ 0
99 ~ 0
124 ~ 0
Air_t Map
Screen 21
-25 ~ 0
-17 ~ 8
-9 ~ 6
-1 ~ 5
5 ~ 4
11 ~ 3
18 ~ 3
24 ~ 0
31 ~ 0
38 ~ 0
46 ~ 0
60 ~ 0
68 ~ 0
82 ~ 0
99 ~ 0
124 ~ 0
Crank Map
Screen 22
-25 ~ 72
-17 ~ 72
-9 ~ 72
-1 ~ 67
5 ~ 62
11 ~ 57
18 ~ 50
24 ~ 41
31 ~ 31
38 ~ 26
46 ~ 20
60 ~ 15
68 ~ 5
82 ~ 0
99 ~ 0
124 ~ 0
t*rpm
Screen 23
Idle ~ 10
1000 ~ 10
1500 ~ 15
2000 ~ 20
2500 ~ 25
3000 ~ 25
3500 ~ 25
4000 ~ 25
4500 ~ 25
5000 ~ 25
5500 ~ 25
6000 ~ 25
6500 ~ 25
7000 ~ 25
7500 ~ ??
8000 ~ 25
9000 ~ 25
t*map Map
Screen 24
Idle ~ 00
25 ~ 05
20 ~ 04
15 ~ 03
10 ~ 02
05 ~ 00
00 ~ 00
2psi ~ 00
4psi ~ 00
6psi ~ 02
8psi ~ -04
10psi ~ -06
14psi ~ -10
16psi ~ -12
18 psi ~ -16
20 psi ~ -20
t*air Screen 25
Correction value Is expressed as number of degrees you wish to advance or Retard to the Ignition curve and values Is set at zero.
t*gap
Screen 26
0500 ~ 15
1000 ~ 15
1500 ~ 15
2000 ~ 14
2500 ~ 12
3000 ~ 10
3500 ~ 10
4000 ~ 10
4500 ~ 10
5000 ~ 10
5500 ~ 10
6000 ~ 10
6500 ~ 10
7000 ~ 10
8000 ~ 10
t*Inj Map
Screen 27
0500 ~ 120
1000 ~ 150
1500 ~ 150
2000 ~ 150
2500 ~ 150
3000 ~ 150
3500 ~ 150
4000 ~ 150
4500 ~ 180
5000 ~ 210
5500 ~ 210
6000 ~ 240
6500 ~ 240
7000 ~ 270
8000 ~ 270
9000 ~ 270
t*wat Map Screen 28
ANd the rest are zero
Option Map
Screen 30
Af_StE ~ 10
Dwell ~ 3.25 *set at Time Base - not at Duty Cycle*
REVstg ~ 2000
MAPstg ~ 02"
%stg ~ 50
Old Mar 3, 2010 | 08:39 PM
thanks alot
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
connerfd3s
Sep 19, 2015 05:58 PM
