problem help
Old Oct 13, 2008 | 11:23 PM
rx7nemesis's Avatar
problem help
hey guys new to the rotory i just got a 94 rx7 and ever time i start it the car die out on me. also its really hard to start the car and when i do i have to keep hiting gas for it to run do i need a new motor???
Old Oct 14, 2008 | 03:17 PM
KhanArtisT's Avatar
Former FC enthusiast
Could be a big vacuum leak or low compression. Test compression first and rule it out if you're unfamiliar with the car. Any additional info on how the car ran prior to this?
Old Oct 15, 2008 | 05:34 PM
dgeesaman's Avatar
Also check the map sensor hose. It's against the firewall above the oil filter. If that's disconnected from the manifold it will act like a blown motor.
Dave
Old Oct 17, 2008 | 09:25 AM
rx7nemesis's Avatar
ya i checked for leaks and i dont have any. am going to do the compression test this weekend ill let u know how that goes
Old Oct 17, 2008 | 09:26 AM
rx7nemesis's Avatar
o yes the map sensor hoes is connected
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
