brake expert needed
Old Oct 13, 2008 | 06:14 PM
20Bforme's Avatar
three spinning triangles
brake expert needed
i cant figure out what the deal is with the brakes on my rx7. everything is new, except the hardlines... new master, new calipers, new flex lines.
the rear brakes bled excellent, took less than 5 minutes to do both. the front on the other hand, is where my problems lie. i cannot for the life of me get the passenger front caliper to bleed what so ever. not sure what the deal is. the driver side i can get to bleed, but it appears that air is getting back into that system. when i pump the pedal to build pressure, the rubber hose fills with fluid. but as soon as the pressure subsides, the rubber line fills back up with air.
could this have something to do with the perportioning valve?
Old Oct 13, 2008 | 06:28 PM
Gene's Avatar
10 lb. boost, 5lb. bag
Did you bench bleed the master?
Old Oct 13, 2008 | 06:39 PM
20Bforme's Avatar
squeeze me? like pre-bleed b4 install?
Old Oct 13, 2008 | 08:47 PM
Gene's Avatar
The new one should have come with some little plastic fittings and hoses that you hook up to the exit ports and point the hoses back into the reservoir.
Instructions here:
http://www.vw-resource.com/bench_bleed.html
Old Oct 13, 2008 | 09:28 PM
rxspeed7's Avatar
F-IT
make sure the front calipers are on the right side. bleeders should be on the top. if not you will never get the air out of them
Old Oct 13, 2008 | 09:55 PM
20Bforme's Avatar
Instructions here:
hmm... interesting... no hoses or anything came with it... ill have to see if i can rig something up...
and yes... the calipers are on the correct sides
Old Oct 13, 2008 | 11:03 PM
alexdimen's Avatar
TANSTAFL
You don't necessarily have to bench-bleed. It just make bleeding easier in the car.
Here's an idea: try bleeding it from the line to caliper junction. Get someone to pump the brakes and hold them, them crack the line open where it goes into the caliper.
I've had calipers and slave cylinder bleeders clog up and have had to do this. I've taken the bleeders compeletely out and gotten no fluid from them.
If it bleeds from the line, I'd take the caliper apart and unclog the bleeder hole.
Old Oct 13, 2008 | 11:15 PM
RacerXtreme7's Avatar
NASA geek
Exactly, pump up the brakes, hold the pressure, then crack the line going to the claliper. Do this several time, then bleed the caliper, you shold be good to go from there.
~Mike...........
Old Oct 13, 2008 | 11:36 PM
The Shaolin's Avatar
Canned. I got CORNED!
bleed bleed bleed bleed bleed!!!!!
Old Oct 13, 2008 | 11:43 PM
20Bforme's Avatar
ill give that a try tomorrow... i also did what you did, took the bleeder screw completely out and still got no fluid...
tomorrow - bench bleed the master, back step to see if there is a clogged line, buy even more brake fluid and more rags...
one thing i noticed when bleeding the driver front, was there was a drop forming on the bottem of the caliper every few minutes... could it be that that caliper has a bad seal where the 2 halfs meet?
haha... i was damn close to screaming that this afternoon... "bleed god damn you bleeeeeeed!!!!"
Old Oct 14, 2008 | 06:04 AM
Turbonut's Avatar
If you have new lines, caliper needs work.
Not likely. Clean the caliper and place some powder on the caliper. You'll see where the leak is starting.
Old Oct 14, 2008 | 06:11 AM
20Bforme's Avatar
all calipers are brand new... well... remans anyways... and by powder... you mean anything? flour?
Old Oct 14, 2008 | 08:23 AM
Turbonut's Avatar
Anything that will adhere to the caliper eg talcum powder, or yes flour. You'll be able to see the path of the leak easily.
Must be a great rebuild job on the new calipers. If you open the line, or actually remove it you'll have fluid running out as it will be an open path, then if you have an air compressor, remove the bleeder and apply air to see if it escapes via the open line connection. In lieu of a compressor, open the bleeder and put a rubber hose over the bleeder and just blow into the hose to see if air escapes. Probably some of the cleaning agents dried inside the bleeder path.
Old Oct 14, 2008 | 04:32 PM
20Bforme's Avatar
well... decided not to go out there today... not in the mood...
but i did stop out there to check on a few things (and pick up my phone). one thing i did notice, was that where the reservoir meets the master cyl. there was a bit of fluid collecting around the seal... could that seal be bad? why would fluid be comming up through that seal? next time im out there i can take some pictures.
i love this car, but this is turning into a nightmare!
Old Oct 14, 2008 | 09:39 PM
20Bforme's Avatar
i just thought of something... could there be air trapped in the master pushing fluid up through that seal when the pedal is pressed?
Old Oct 14, 2008 | 11:10 PM
alexdimen's Avatar
TANSTAFL
I don't think that's possible. If that could happen, the fluid gets to a much higher pressure by itself (since it doesn't compress) and would ooze out worse.
Not a big deal, if it seeps from there just buy some new resevoir seals/grommets.
You seem to be overcomplicating it. Cracking the line at the caliper will tell you whether it is a clogged line or clogged bleeder hole.
I'd bet there's **** in the bleeder hole from the rebuild.
Old Oct 14, 2008 | 11:31 PM
20Bforme's Avatar
god i hope your right...
Old Oct 15, 2008 | 12:27 AM
Osirus9's Avatar
Jackstand Drifter
I had a similar problem while bleeding my cousin's brakes. it turned out that there was a chunk of rust lodged in the actual bleeder, and when I pried it out the bleeding process went along normally. I'd put money on some sort of clog in your caliper or the line.
Frisky Arab
13
Aug 18, 2015 05:30 PM
GrossPolluter
Aug 16, 2015 09:50 AM
