? port wastegate w/ street-port, resonated mid-pipe, DP, cat-back, stock twins, PFC ?
Old Oct 13, 2008 | 04:44 PM
M104-AMG's Avatar
I'm installing a street-ported engine with 4x850cc injectors, with a DP, resonated mid-pipe, cat-back, on stock twins with a very conservative Steve Kan tune on a PFC.
So the only thing different from my previous setup is the street-ported engine, and the possibility of a free-flowing intake system (e.g, Pettit or Apexi-style intake).
If I keep the STOCK intake airbox (big restriction), I don't think I need to port the wastegate.
What if I go to a Pettit or Apexi-type intake (less restriction), do I need to port the wastegate ?
FWIW, I have never experienced boost-creep before (stock airbox/intake w/Cheap Bastard mod); stock engine; 4x850cc injectors; stock turbos, DP, resonated mid-pipe, cat-back, PFC).
If install BNR Stage III sequential turbos, I assume I'd have to port the wastegate.
TIA,
:-) neil
Old Oct 14, 2008 | 04:34 AM
GARCO MOTORWORKS's Avatar
Just open the hole to 1.24 inches and there is no need to guess .The cost is small and you are done with it .To be sure that you are safe if you turn the boost up on the BNRs open the hole to fit the bigger door that you installed .I use the prespool door on some jobs and make even bigger doors when needed .
Old Oct 14, 2008 | 09:25 AM
adam c's Avatar
Cheap Bastard
With your (Cheap Bastard ) modified airbox, you do not have a restrictive intake. It will flow as well as any hot air intake, except with cool air.
I would port the wastegate if the engine/turbos are out of the car. There is really no reason not to do it.
Old Oct 14, 2008 | 12:30 PM
Speed of light's Avatar
Form follows function
I believe BNR 3's include a ported waste gate... mine did (and are the early version).
In any event, porting does seem to improve boost control, so I would recommend it.
Old Oct 14, 2008 | 01:23 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
Yes, BNR 3s come with a ported wastegate. Bryan ports it for you before it's shipped out.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
Engine stand ready
Aug 14, 2015 10:26 PM
bb6guy
Aug 12, 2015 03:29 PM
