Primary-Secondary injector confusion,,help
Old May 13, 2002 | 01:12 PM
LLADNAR's Avatar
well the way everyone talks on here the primary fuel rail is the upper rail and the secondaries are the ones on the block and close together. well that is the way i understood it anyway.
well my service manual says the primaries are the small rail and the secondaries are the long rail,,,well then i am screwed,,,based on my previous understanding i replaced the two on the small rail with 650cc. and i can't just swap them back becuse i had to modify the rail.
so the book is right isn't it??
please tell me it is a typo or something.
Old May 13, 2002 | 01:15 PM
Samps's Avatar
The primary rail is the small one. Think about it; the small one sprays fuel directly into the combustion chamber while the larger rail sprays way upstream of the motor.
I know the feeling; earlier today I had the PD and the FPR backwards.
Old May 13, 2002 | 01:24 PM
LLADNAR's Avatar
well **** can i just use those for the moment as primaries and still use my 550cc secondaries. then maybe get another set of 650ccs later.
Old May 13, 2002 | 02:16 PM
Samps's Avatar
You'll probably run preaty rich but I can't see why it wouldn't work. Look at it this way, you're ready for a big turbo upgrade now, and SOUL's selling his TO4!
Old May 13, 2002 | 02:42 PM
LLADNAR's Avatar
well can't i just get a boost controller and crank up the boost a little
Old May 13, 2002 | 03:42 PM
blu_gxl's Avatar
can't you just reverse the 550 and 650's? they should be the same diameter i think just one is longer than the other.
james
Old May 13, 2002 | 04:55 PM
LLADNAR's Avatar
james
can't switch them,,,the 650s are a larger diameter,,and the fuel rail had to be drilled to fit so no i can't swap them.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
bryancmatthews
Power FC Forum
Sep 5, 2015 03:57 PM
doritoloco
Sep 5, 2015 12:41 PM
