Any feedback on this eBay short shifter
Old Oct 12, 2008 | 10:50 PM
clied's Avatar
Shinryuken
http://cgi.ebay.com/ebaymotors/90-97...=p4506.c0.m245
I tried searching and came up with a few threads about people using a Miata short throw shifter found on ebay. But the ebay links were all dead so I couldn't tell whether they were talking about this shifter or a different one. I question the shifter because of the price but if theres anyone here that has actually bought and installed one of these I'd like to know what you're results were. Was it worth it and did it bolt right in without any modifications to the shifter? I wouldn't mind picking it up if not much has to be done to install.
Old Oct 12, 2008 | 10:51 PM
luckyfd's Avatar
is that normal?
looks just about right do it!, but if you can find a c's short throw it'll be much better buy in quality. i know so i have one
Old Oct 12, 2008 | 10:59 PM
clied's Avatar
Shinryuken
Trust me, If I had the money I'd for sure get a C's short throw shifter but I don't.
Old Oct 12, 2008 | 11:58 PM
misterstyx69's Avatar
Retired Moderator, RIP
here..I felt like being a good guy.. https://www.rx7club.com/showthread.p...+Miata+shifter this write up tells you what you have to do.,.the best Thread I have seen for it..But nothing beats a C's or Mazdatrix.
Old Oct 13, 2008 | 12:59 AM
jdm_emperor's Avatar
i didnt like it, had it in for a day
Old Oct 13, 2008 | 01:27 AM
clied's Avatar
Shinryuken
Can you tell me what you didn't like about it ?
Old Oct 13, 2008 | 02:21 AM
89rx7vert's Avatar
yea i want to know too?
im not about to spend 200 on a mazdatrix one...
Old Oct 13, 2008 | 04:12 AM
clied's Avatar
Shinryuken
$200 dollars ain't too bad, but I guess compared to the eBay shifters price it does. I'm all for paying that amount for a great shifter but if the eBay shifter comes close in quality and finish then I'd rather have that extra $170 in my wallet then buy a brand named product.
Old Oct 13, 2008 | 04:24 AM
clokker's Avatar
Cake or Death?
That appears identical to the shifter I got (also from eBay).
The only advice I'd offer is to pay very close attention to the bushing/shifter fit...I spent a few hours using shims (washers from Ace Hardware) to get the ball of the shifter to seat exactly with the retaining ring fully tightened.
I haven't tried a Mazdatrix unit but I'd guess you'd have to do the same thing.
I think you'll also find that any short shifter benefits from a heavy shift ****.
I used a Nismo competition unit but anything with the appropriate thread pattern will work.
Because my **** is taller than the normal version, I ended up machining the upper shaft to lower the installed height. This was easily done on a lathe (once you get through the chrome plating) and resulted in a very stubby shifter.
However, even though the throw is only @2 1/2", it's easily flicked with just wrist action, very positive feeling and doesn't rattle.
When installing any of these, be sure to get all new rubber seals/gaskets and top off the oil in the shifter linkage chamber.
Old Oct 13, 2008 | 05:27 AM
clied's Avatar
Shinryuken
Thank you!
Just the post I was waiting for.
Old Oct 13, 2008 | 09:58 AM
Houstonderk's Avatar
My girl
When I got one the plastic piece at the very bottom wouldn't fit it the trans so I had to cut it up, the black plastic guide piece cracks easily and about a week later I found myself putting the stock back in as that one had came out shifting to 1st gear. Maybe just got a bad one. Who knows.
Old Oct 13, 2008 | 01:28 PM
clokker's Avatar
Cake or Death?
The plastic bush at the bottom is going to be a bit too large but sandpaper quickly gets it down to size.
My pivot bush (black plastic on the pivot ball) is still fine but if you were concerned you could always order a stock Mazda unit.
Old Oct 13, 2008 | 03:22 PM
lov-2-rev's Avatar
Mr. Nice Guy
From: Jamesport, NY..."Movin' on up, to the east side!"
I've had a miata shifter in my FC for a bit more then 2 years and about 20k miles. I think it's a great short shifter for the price. It tends to be a bit 'notchy' fealing compaired to some of the more premium brands. Then again, you're also paying about 6 times the price.
With a little work the miata shifters can be made to work pretty well. Sometimes you need to shave down the lower bushing provided, so it fits into the FC shifter linkage properly. I also spent about 45 minutes trying different spacer combinations to keep it from binding up. Just remember to get new shifter bushings when installing. It makes all the difference.
The black plastic guide at the bottom of mine has worn, so the shifter has a touch of twist movement, but hasn't broken.
As mentioned above, these miata shifters definitly benifit from having a weighted shift **** on them. It really helps smooth out a bunch of the 'notchy-ness'. I'm using an Rx-8 **** with a little extra weight added and it is a noticable difference compaired to the origional s5 ****.
Old Oct 13, 2008 | 03:30 PM
Hypertek's Avatar
Slowpoke
nvm
Old Oct 13, 2008 | 04:32 PM
89rx7vert's Avatar
Is this the bushings that you need?? or is there other ones??
http://cgi.ebay.com/ebaymotors/Mazda...=p4506.c0.m245
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
The1Sun
Sep 15, 2015 04:45 PM
BLK 93
11
Sep 9, 2015 10:56 AM
