installed new fuel pump car wont start
Old Oct 12, 2008 | 07:27 PM
karl0003's Avatar
WA installed new fuel pump car wont start
i installed my new supra pump today and got in to start the car. turned the key i heard the fuel pump whine in the back thought that was a good sign. then turned the key but the car wouldnt start. it tries to start but it just seems like the engine isnt getting any fuel. any ideas please let me know. thanks
Old Oct 12, 2008 | 07:49 PM
gafu mazda's Avatar
el unico
hoses on right?kinked hose?air(I think that's a stupid question)?flooded?check plugs.Good luck
Old Oct 12, 2008 | 08:29 PM
Mahjik's Avatar
Mr. Links
Have you checked to see if you are getting fuel pressure?
Old Oct 12, 2008 | 08:34 PM
GreatShamanGT's Avatar
Roxann7
make sure the O-ring is adequetly put on and it's not leaking.
Old Oct 12, 2008 | 08:38 PM
karl0003's Avatar
how would i check if its getting fuel pressure? sorry for the noob question. ok i will recheck the o ring and see if thats the problem.
Old Oct 12, 2008 | 09:27 PM
mono4lamar's Avatar
In the burnout box...
Take a mechanical pressure gauge and "t" it inline with the feed line in the engine bay. One more thing. It's pretty impossible but maybe you crossed the feed and the return lines on the carrier. Goodluck!
Old Oct 12, 2008 | 10:37 PM
FearNoPiston's Avatar
FREAK ALL OUT!!!
^yes make sure you put the neck on that holds the O-ring on otherwise fuel will just fall back into the tank.
pull the fuel pump and inspect the o-ring see if it fell down.
Old Oct 12, 2008 | 10:59 PM
IRPerformance's Avatar
Sponsor
Also make sure you didn't switch the feed and return hoses. The pretty much point to where they should go.
Old Oct 12, 2008 | 11:06 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
and make sure the wires are hooked up correctly too, otherwise the pump runs backwards
Old Oct 12, 2008 | 11:48 PM
fd0's Avatar
fd0
formerly chillin_rx7_guy
Other thing to try is priming the fuel a little more. The FSM recommends turning it on but not starting at least a couple of times before starting. Try doing that too. You should hear that whine sound at least 3 times to be safe.
Good luck.
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
