Increasing Turbo Boost
Old Oct 9, 2008 | 01:14 AM
FD3S_B00ST's Avatar
RIP User Name** FD3S4LIFE
hey i recently purchased a 1993 twin turbo FD but the guy i bought it from turned the boost down to 8 so i dont blow the new motor at first. well ive broken the new motor in and wanna get the boost up to 10 or even 12...but i dont know how to do it...any suggestions?
Old Oct 10, 2008 | 03:15 AM
RotaryRocket88's Avatar
Top Down, Boost Up
The car has to have some sort of boost controller. Electronic or manual. You'll need to find it and learn how to make adjustments. 10 PSI should be stock boost on a FD (correct me if I'm wrong; not a 3rd gen expert), so even if the fuel system is stock, you'll be safely in the rich range if you keep it there. If I were you, I'd find out if the fuel system is modified or stock before raising it any higher than that. It's probably good for 12PSI, but don't guess.
Old Oct 10, 2008 | 10:42 PM
FD3S_B00ST's Avatar
okok cool thanks for the help
i was thinkin 12 but gas is already killin me on this car so ill settle at 10 for noww
Old Oct 13, 2008 | 01:42 PM
joel_rx7's Avatar
The stock boost pattern on FDs is actually 10-8-10.
Below 3000rpm the first turbine gives you 10 psi alone, between 3000 rpm and 4500 rpm some of the exhaust flow from the first turbine is re-directed to the second (and bigger) turbine to give it some speed, the boost is then 8 psi. And above 4500 rpm all turbines are working are up to speed to give you 10 psi.
Old Nov 4, 2008 | 02:35 PM
FD3S_B00ST's Avatar
thanks again
FD3S_B00ST's Avatar
thank you again
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
