Sponsored by: CARiD
Hot Start Problem. Any advice is appriciated.
Old Oct 7, 2008 | 07:06 PM
xxmicrozxx's Avatar
1 Slow 7
My fd doesn't like to start up once the car is hot. The car will start fine when is cold, but after there is heat in the motor, and i try to start it, it will crank over trying to start but will not fire over until the car is running at about 160 degrees.
There is fuel pressure when we try to start the car after its hot.
We've replaced:
  • Fuel Pressure Reg.
  • Air Control Valve
  • Air Pump
  • Starter Solonoid
  • Starter
Any advice is good advice at this point.
Thanks guy.
Old Oct 9, 2008 | 08:19 AM
xxmicrozxx's Avatar
1 Slow 7
Anyone?
Old Oct 13, 2008 | 06:46 PM
Mills's Avatar
procrastination engineer
S4 or S5? If S5, will it start with the throttle to the floor while cranking? You may have a fuel injector leaking when shut off causing flooding or possibly have low compression, another problem that causes hot start issues.
Old Oct 13, 2008 | 07:14 PM
hondahater's Avatar
spending too much money..
I'm pretty sure he said fd. I'm not sure about the fd but it is probably like the s5 in the fact that if you hold the throttle to the floor it will turn off fuel allowing the car to start. You should check for A) Leaky Injectors and B) compression. Good luck.
Old Oct 13, 2008 | 07:38 PM
R-R-Rx7's Avatar
Rotor or no motor
do a compression test
The1Sun
Mar 18, 2018 11:08 PM
Microtech
30
Apr 23, 2016 06:37 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
