Rear disc brake rebuild
Old May 12, 2002 | 08:35 PM
mikeygogo's Avatar
Newbie
Help.....if you have ever rebuilt a rear disc brake caliper. I have completed the rebuild but I am having difficulty seating the rubber boot back into the piston chamber. It is held in place by a wire clip that is seated inside the boot. How in the world do you get this clip to stay in place?
There has to a trick
Thanks
Mike Aubrey
Old May 13, 2002 | 11:39 PM
twinturborx7pete's Avatar
Juris Doctor
do you have all the tools to do this job?
Old May 14, 2002 | 10:50 AM
mikeygogo's Avatar
Newbie
Yes......however based upon discussions with other 7 owners there is no tool for this job. I was hoping someone had done this rebuild and could share a trick for reseating this ruuber boot.
Old May 14, 2002 | 11:42 PM
I looked into rebuilding the rear calibers a while back, I was told that it is more difficult than the fronts. They also said that rebuilt rear calibers from Mazda were relatively cheap (I think it was around $60, with exchange). If you consider the value of your time and the cost of the rebuild kit, buying rebuilt calipers from Mazda might be more cost effective.
I am not sure if this is helpful to your current situation but ....
Old May 18, 2002 | 05:18 PM
ZoomZoom's Avatar
SEMI-PRO
Good price. How about the fronts? $$? Mazda Comp? Mazda dealer?
Old May 19, 2002 | 01:35 AM
Silkworm's Avatar
Has been.. hangin' around
I put the boot over the piston, and screwed the piston down to almost flush. Then I grabbed one end of the clip with needlenose, inserted the other end, and worked it down and around the boot.
PITA, sorry, it's not easy. But it's easier than 300 bucks for rebuilt rear calipers.
The fronts cost me ~70 bucks ea rebuilt.
PaulC
Old Jun 13, 2007 | 07:07 PM
katit's Avatar
Pretty old post here Sorry for bringing it back up.
Need some info on rear brake rebuild kit.
Mazdatrix has one for $40 PN 26-44Z0-FDY1
and Ray said that he lists 46Z as correct one and it's $60 and he can get 44Z for $33
What's the deal here? What is the difference?
Old Jun 14, 2007 | 09:49 AM
katit's Avatar
Hm. Nobody knows? Is there any way to check what this 44Z kit applies to?
Old Jun 14, 2007 | 10:27 AM
gracer7-rx7's Avatar
needs more track time
I'll put money on Ray b/c the guy is a living, breathing, walking FD encyclopedia
Old Jun 14, 2007 | 04:40 PM
katit's Avatar
Ok. 44Z is an internal seal kit, rebuilds calipers but does not have external dust boots and so on. I'd say I need 46Z..
mazdaverx713b
48
Apr 21, 2016 06:45 AM
