Dyno
Old Sep 28, 2008 | 08:25 PM
20B-3Rotor's Avatar
Haltech Dealer
Dyno
So I had my car tuned again by Steve Kan this weekend. Last year I made 540rwhp @ 13psi With ignition break. So with the new Msd Setup this year. It made 604rwhp @ 15psi and then the turbo blew. The MSD set up worked great.
Steve Was amazing again as always.
This was on a Dynapack.
I will post the dyno sheet tomorrow
Old Sep 28, 2008 | 08:57 PM
soloracer951's Avatar
Congrats! Any chance you could post the dyno sheet? I'm curious as to what the HP/TQ curves look like. Is the engine ported?
Old Sep 28, 2008 | 09:01 PM
20B-3Rotor's Avatar
Haltech Dealer
The engine is streetported
Old Sep 28, 2008 | 09:16 PM
20B-3Rotor's Avatar
Haltech Dealer
dyno sheet
Old Sep 29, 2008 | 03:04 AM
TwinGTR's Avatar
nice numbers!
What GT42 are you using?
Old Sep 29, 2008 | 09:16 AM
onefast93RX7's Avatar
good numbers...that's a very nice torque curve
Old Sep 29, 2008 | 04:14 PM
thetech's Avatar
****** of disaster
I used 2 MSD DIS-4's with the Blaster coil packs and it was basically flawless. I did have one issue on the dyno one time where they appeared to overheat or something and would not fire the coils until they cooled down for 30 minutes.
Good numbers though!
Old Sep 29, 2008 | 05:12 PM
20B-3Rotor's Avatar
Haltech Dealer
I also used two dis-4 plus and 8207 coils
here is a little write up on the dyno day
http://www.u2ndyno.com/index.php?act...mments=1&id=30
Old Sep 29, 2008 | 05:46 PM
87 t-66's Avatar
not a drifter
awesome! congrats.
Old Oct 3, 2008 | 09:25 PM
20B-3Rotor's Avatar
Haltech Dealer
Originally Posted by TwinGTR
nice numbers!
It wasn't the ball bearing one...
Just got a new ball bearing cartridge for the turbo so hope this one last.
Old Oct 4, 2008 | 05:02 AM
TwinGTR's Avatar
The Gt4294 then? What Turbine housing did you use?
Have these turbo blown or why are you changing?
Old Oct 5, 2008 | 12:06 AM
20B-3Rotor's Avatar
Haltech Dealer
Well just put in the ball bearing cartridge today and took it for a ride. It is crazy..... It is worth the money for the ball bearing one... Just got home from taking it on the highway was going on the on ramp and put it in 3rd gear and put my foot into it bam!!!. 3rd gear blew.... So now i guess i have too much power for the stock transmission.
Old Oct 5, 2008 | 08:47 PM
t-von's Avatar
Rotor Head Extreme
^ That extra low end torque is a ****.
Old Oct 10, 2008 | 10:47 PM
black93RX7's Avatar
20BFD
Are these the exact ignition parts you are using?
http://www.horsepowerfreaks.com/part...laster_SS/2048
http://www.horsepowerfreaks.com/part...ems/DIS-4/1962
Old Oct 11, 2008 | 07:43 AM
20B-3Rotor's Avatar
Haltech Dealer
[QUOTE=black93RX7;8628419]Are these the exact ignition parts you are using?
QUOTE]
I sent you a pm
Old Oct 11, 2008 | 12:30 PM
crispeed's Avatar
'Tuna'
Congrats!!!
Steve is the man!!!
Old Oct 14, 2008 | 03:28 PM
lexusboy's Avatar
Newbie
Congrats....that's great power
Old Oct 14, 2008 | 07:05 PM
rx72c's Avatar
Top Answer: 1
excellent power.!!!
Just out of curiousity? it seems the power hasnt started dropping off yet? any reason for not pushing more on the dyno? and possibly more boost?
Old Oct 15, 2008 | 07:57 AM
20B-3Rotor's Avatar
Haltech Dealer
Ya well the motor is not balanced or studded so I guess steve didn't want to take it any higher.. Was going to run another pound of boost but at 14psi the turbo let go...
It would be nice to see what the ball bearing turbo will do now...
Rotate86
May 18, 2018 02:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
