Starting problem.
Old Sep 25, 2008 | 10:31 PM
BungaloBob's Avatar
Zoom-Zoom
Starting problem.
So after a few weeks of bringing my FC back from the dead, it finally works and runs great.
The only problem is after i run it for a while, if i turn it off it doesn't start back up. IT will eventually, after i've let it sit for a bit.
To me, it just sounds like its flooded, but I'm new to rotaries so I'm hoping it's nothing else.
Old Sep 27, 2008 | 03:28 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Common hot-start issues. Leaky fuel injectors cause it, and sending them out to be cleaned will help. I use Witchhunter Performance (http://www.witchhunter.com/); $18 per injector.
To help for now, pull the green 40A EGI INJ fuse under the hood, spin the starter, put the fuse back & start the car. This is the flood clearing procedure. Pulling the fuse keeps the fuel pump from running.
Old Sep 29, 2008 | 07:28 PM
jiangwei's Avatar
I also have a problem starting my 1986 non turbo. The vehicle hasn't been touched in 5 years and recently I inherited the vehicle from my uncle. The car wiring has been chewed up due to being left in a barn and mice most likely chewed it away. We did manage to get the vehicle to turn with some splicing of the wiring but it still struggles to start. I hope I can get some suggestions of how to get the vehicle started and running for now.
Thanks in advance.
Old Sep 29, 2008 | 10:47 PM
BungaloBob's Avatar
Zoom-Zoom
Thanks in advance.
With mine, all it needed was an oil change and some new spark plugs.
(Well, that and a massive amount of carb cleaner sprayed into the intake.)
If you haven't already, i suggest you start there.
Old Sep 30, 2008 | 08:39 AM
jiangwei's Avatar
thanks bungalow
1987 T2
11
Apr 1, 2017 11:59 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
gabescanlon
Sep 5, 2015 12:09 AM
