Heart Transplant Successful! Well....almost
Old May 11, 2002 | 08:22 PM
85RX7GS's Avatar
Lightbulb Heart Transplant Successful! Well....almost
In case you didn't know, I had an exciting experience driving home from school one day - an apex seal cracked on the rear rotor of my 85 12A. I decided to order a new engine and install it myself. Anyway, after many weeks of hard work, I started the car up today. With a cloud of smoke and a roar, it came back to life (after messing with the idle mixture screw a tad). It drives great and sounds awesome!
The problem is that the tachometer doesn't work. It did work until I parked it for the engine transplant. Any ideas? TIA.
BTW - Thanks to all who have helped me get my car back on the road.
Old May 11, 2002 | 08:28 PM
jeremy's Avatar
male stripper
make sure your wiring is hooked up correctly. you're probably not getting a signal.
Old May 11, 2002 | 08:32 PM
85RX7GS's Avatar
When you speak of wiring, which wiring? Where is it located and where does the signal come from? Thanks Jeremy.
Old May 11, 2002 | 08:38 PM
Felix Wankel's Avatar
Super Newbie
Trailing coil.
Old May 12, 2002 | 12:11 AM
REVHED's Avatar
Hunting Skylines
Did you use the dizzy off the old engine or did the new engine come with one? If you're using a new dizzy then it probably has a dead trailing ignitor.
Old May 12, 2002 | 12:59 AM
riffraff's Avatar
smog nazi destroyer
i ended up with the same problem when i did my body swap. wish i knew what it was...
Old May 12, 2002 | 07:32 AM
85RX7GS's Avatar
Ok, I'll check the coils out. The connections do look a little rusty, but then again, it was working prior to when I parked it.
I'm also using the old distributor that was on the old engine. I'll check out the contacts on the ignitors and spray some contact cleaner on them.
Old May 12, 2002 | 07:44 PM
85RX7GS's Avatar
Corrosion on cables. Tach now works fine.
cook11
V-8 Powered RX-7's
Oct 2, 2015 11:52 AM
SpaceCadet_Alt3
Oct 1, 2015 11:35 PM
scissorhands
Sep 14, 2015 03:48 AM
