ok... I need help... what can I yank of my carb??? And another Q...
Old May 11, 2002 | 01:48 PM
79+80_rx-7's Avatar
OK..... I got the air horn off my carb, cause it wont run right.... it will start, and then stall..... then I could pump the gas.... and it would start again...... so I was told that I need to clean the jet,bleeds, ect...ect...ect.... well... I am doin this now..... I am wondering.... what can I yank off my carb??? I mean.... there is a bunch of **** on it..... I dont care about emissions, or a choke.... So... what can I yank?
Oh yeah... what should I clean the carb with???
THANX.... LATERZ... Andrew
Old May 11, 2002 | 04:25 PM
REVHED's Avatar
Hunting Skylines
When I had the Nikki I ripped basically everything off the carb and it worked perfectly all the time.
The only things left were the throttle linkage, choke linkage and OMP linkage.
I left the choke linkage on so I could keep the revs up when the engine's cold but the actual choke plate and shaft were removed.
Old May 11, 2002 | 04:34 PM
79+80_rx-7's Avatar
THANX SOOO MUCH... I guess I will go ahead and yank alot of **** off.....THANX
Well.... all my **** was ALLL gummied up... and FILTHY with corrosion... so I cleaned most of it.... poored gas down where the float are.... turned it over... she sarted right up.... and purred until the gas was gone... so I am now cleaning my ****.... AND THEN GO HAVE SOME REAAL FUN THANX EVERYONE
scissorhands
Oct 8, 2015 01:17 PM
