FC tps help
Old Sep 20, 2008 | 05:39 AM
hello kitty's Avatar
hawaii status!
FC tps help
my FC only revs to about 1.5k... should i get a new tps or adjust the one on the car?
Old Sep 20, 2008 | 05:43 AM
Turbonut's Avatar
Hard to focus on the question, but check it first to verify condition.
Here's just a couple quick hits:
http://www.johnr.com/tps.html
http://howto.globalvicinity.com/gv_w...i=58&co=1&vi=1
Old Sep 20, 2008 | 06:05 AM
hawaii status!
hmm thanks for the help. ill try spinning that screw
Old Sep 20, 2008 | 06:06 AM
hawaii status!
oh yeah one more!!! does the T1 spark plug wire go on the top hole closer to the tranny or further???
Old Sep 20, 2008 | 06:42 AM
HAILERS's Avatar
HAILERS
Pull the connector off the TPS and see if it revs higher or closer to normal. If it still runs as bad as you describe, you've another problem altogether. Takes but a moment to pull the plug off and see.
Old Sep 22, 2008 | 03:44 AM
hawaii status!
ope i got it fixed, replaced the tps! runs cherry now
Old Sep 22, 2008 | 04:47 AM
HAILERS's Avatar
HAILERS
What happens, is the plunger inside the TPS sticks and causes a malfuncton. You look at the plunger of the tps and it might seem to go in/out, but the internal part of the plunger is stuck in one positon. This causes sort of a fuel cut conditon, so you get no rev's. Been there, done that. Only thing that fixed the problem was unplugging the TPS. Forturnatley I freed up the TPS and it worked for a bit after that episode.
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
